Biltema 84-1511 BT-speaker Spinorama measurements (CTA-2034)
What are your thoughts about this speaker?
  • Very good
    Votes: 12 57.1%
  • Above average
    Votes: 1 4.8%
  • It's ok
    Votes: 3 14.3%
  • Below average
    Votes: 2 9.5%
  • Poor
    Votes: 3 14.3%
Here are some measurements of a Biltema 84-1511 Bluetooth speaker.
The current price in Sweden is 129 SEK (~12.9 USD).
Biltema is like a Swedish mix of Harbor Freight and Canadian Tire, but they only sell products with their own brand name.
The 5m (~16.4 ft) 3.5mm cable used was 59.90 SEK (~5.99 USD), well above the recommended 10%, and of course it's from Biltema as well, for perfect synergy. I didn't have time to do any cable burn-in though, but it should only affect the subjective performance, since it's not measurable.
To make sure that I was only using clean power during the measurements, both the speaker and my Macbook Pro were running on battery - no chargers connected.
I had to put the speaker on a glass to reduce reflections from the stand, but don't worry. The glass is transparent.
CTA-2034 data:
The 1.6 inch woofer drops off below 400 Hz.
Sound power, early reflections and directivity index are all interesting, most likely because of the up-firing driver.
Vertical 0-deg axis is with the driver at a 90 degree angle, to get the same "on-axis" response as the horizontal 0 deg.
Early reflections:
The very bright ceiling bounce is expected with the up-firing driver. Maybe you could use this speaker for Dolby Atmos?
Estimated in-room response:
Horizontal directivity:
Vertical directivity:
Near-field:
The woofer was distorting (audibly) quite a bit at 72 dB SPL / 1m (82.5 dB @ 30 cm), so I didn't measure at higher SPL.
Obviously bad below 300 Hz, but surprisingly low distortion > 500 Hz.
Listening test:
I started by listening to Eiffel 65 - Blue:
Imagine a large, open and detailed sound, with all veils lifted. It's like you were there at the recording session. Both micro- and macro-dynamics are impressive for a speaker of this size.
I then listened to a number of reference tracks, and I have to say that this little speaker is quite impressive. It needs a subwoofer (or well, a woofer) but imaging is excellent and overall tonality is quite neutral.
Well, that would be very impressive, if it was true.
(The measurements are real though)
Out of respect for the tester and because I think it is the lowest score so far.
No EQ
LW EQ:
Score/flat Sound Power
