MM capacitive loading with stock Technics SL-1200GR or SL-1500C
Anj
This being my first post on the forum, and in the spirit of objective measurement, I measured the stock connecting cable and tonearm cable without the headshell using a capacitance meter. The error for the range I used is + or - 1%. The SL-1200GR connecting cable alone measured 80 pf. When connected to the turntable the measurement rose to 106 pf. Therefore the tonearm cable only presents approximately 26 pf. The SL-1500C connecting cable measured differently for each channel: 115 and 109. Tonearm cable alone is approximately 32 pf. These measurements will hopefully be useful when calculating total load on a particular cartridge.
In practical application it helps a great deal to know the load presented by the phono input. I don’t have a way to determine the load presented by the internal phono preamp on the SL-1500C. My guess is that it is optimized for the stock Ortofon 2m Red cartridge. Ortofon specifies a desired range of 150-300 pf for the 2m series. Tonearm/headshell cable aside, can we conclude that the capacitance of the internal preamp is between 118 and 268 pf? Your guess is as good as mine but that seems reasonable.
In the days when Shure (250 pf for the M9x and V15typeVmr, and 400-500 pf for the V15typeIII) and Stanton (275 pf for the 681eee and 881s) cartridges were available, higher specified capacitive loads were common. Even the Ortofon OM series which is about 3 decades old specifies 200-500 pf as a suitable range. Audio Technica was an outlier with 100-200 pf and have remained consistent to this day. Sumiko currently specifies 100-200 pf for the Oyster series. Nagaoka does not list values on their website. Therefore, when combined with the phono input capacitance, the use of the stock Technics connecting cable is likely to bring the load out of range for certain brands.
My guess is that 47 pf at the phono input (Rogue RP-5, Schiit Mani 2) is an exception; values of 100 pf and higher are more common. How, then, can the load be brought into range? Faced with this problem I ordered a Blue Jeans LC-1 cable in a 2 foot length which measures 32 pf (terminated). Therefore, I was able to interface my SL-1500C with my phono input of 100 pf and come up with a total load of approx. 164 pf. This works for the Audio Technica and Sumiko cartridges. The stock Technics cables will likely be suitable for Ortofon. The jury is out on Nagaoka.
mike70
Thanks for sharing ... I can say that in ebay you can find RCA terminated cables with Mogami low capacitance for 1/2 or 1/3 the blue jeans price
Digby
I tried to start a thread about this, asking why AT are outliers in this. Is there a technical reason? It doesn't make sense, at least with cheaper gear, where the consumer is unlikely to know about/be able to adjust loading, to go with a very different spec than most everyone else. Do you have any insight into why this may be?
DSJR
Suffolk Coastal, UK
Before my ears became terminally bad, I did some brief experiments with a phono preamp able to flick dip switches for loading. I'd ask respectfully PLEASE not to worry overmuch these days with more modern designs (Ortofon in the case of the SL1500C and AT VM95 with the SL100C). The 2M designs (based on the OM inners I gather) don't seem as fussy on loading as their VMS ancestors were and the VM95's seem pretty ok as well with a typical 200pF loading. Fine tuning the VTA and tracking force will almost certainly do more I think. not sure you need ot lok at other MM types although Grado and Nagaoka as well as the old fashioned but beefy toned Sumiko MM's have their fans still in more retro systems.
As for Shures, the last ones (V15V and descendants, 97XE and so on) gave you a choice. Low capacitance meant a gentle 5dB downtilt from 1kHz to 20kHz and increasing it tended to flatten the response to 10khz after which it also fell to -5dB at 20kHz. My V15 III (new old VN35E stylus) is as hard toned as it always was (the VN35HE was a revelation once it came over here) and changing capacitance doesn't alter this characteristic I remember when I tried.
Digby
@DSJR From what you say, it sounds like things are going in the right direction then, in that loading is less of a factor with modern carts and they are happy with typical ranges available from any sensible equipment you may use. I wonder why this took so long for manufacturers to figure out and somewhat standardise? It seems to me the kind of thing you want a standard for 99% of the time, save at a high price point where people will have knowledge of, and access to equipment that can easily accommodate different loading.
DSJR
Suffolk Coastal, UK
I'm way out of it now, but I believe that 'digital' as in CD to start with, was th ebest thing that ever happened to vinyl record reproduction, as at last, 'we' had a proper easily verifiable reference to aim for. I appreciate the vinyl diehards still sniff and even sneer at digital, but that's their ignorance (intentional or otherwise) talking there.
If my stash of old turntables (Duals, Garrard autos and Duals and a Lenco or two and a Thorens 160mk2 sans arm) went up in smoke, much as I 'ought to' buy a Rega 6, I'd probably go to an SL100C or maybe the full-kit 1210mk7 as they'd see me out and be easily usable for any descendants or inheritors... I'm also a 2M and AT fan as well and can pick and choose without angst here :)
dlaloum
If you can find the circuit diagram for the SL1500C inbuilt phono stage, you might be able to identify the C loading...
You can change the "voicing" of a cartridge by adjusting the parameters - the H of the cartridge body, the C and R of the loading adds up to an EQ curve.
This is balanced against the resonance that all stylus cantilevers have - the better the cantilever the higher the frequency at which the 1st resonance happens - at that frequency you get a bell curve of rising sensitivity/output (along with rising distortion, reduced tracking ability etc...) - and after the resonance bell curve, you typically have rapidly dropping sensitivity (as it starts to get beyond the needles ability to track the modulations due to its effective mass)
Basically you use the loading EQ to balance out the resonance and try to achieve a relatively flat frequency response.
The very best exotic cantilevers, with ultra low effective mass, can move the resonance frequency beyond the audible range - making the whole loading process much easier...(Shure V15VMR moved it out to around 32kHz - leaving nothing but a hint of a rise around 20Khz, easily compensated for by light loading)
Today, exotic cantilevers are rare on MM's - and the standard aluminium cantilevers have resonances which range from around 10khz to 15khz followed by a steep drop off
You can model the EQ curve, and then deduct it from a cartridges measure response to identify (roughly) the core cantilever response...
You can then vary the EQ curve model (try various loadings) - the identify the optimal FR - before applying it to the cartridge and seeing how the system responds.
Yes it is a rough estimate - but you can get surprisingly good results with a wide variety of cartridges using this method.
Another interesting thing - various manufacturers have had "families" of cartridges with styli interchangeable between them (Shure, AT, Stanton, JVC)... the differing bodies in that family typically have different inductances - sometimes the trick to getting the optimal combination for a given stylus is to vary all 3 (H/C/R).
sktn77a
The V15/III was not particularly sensitive to loading capacitance, unlike its predecessors (the infamous midrange droop) or its successors (high end rolloff). The M97xE, and most of the current AT VM5xx/7xx series, are acutely sensitive to input capacitance, rolling off the high frequencies with anything over about 250pF. For example Naim MM phono preamps (stand alone and integrated) have an input capacitance of 470pF which, with a typical tonearm wiring and cable give a total of over 600pF.
I use a MC setup right now but an considering moving to MM in my declining years. When I do, I suspect the NAIM stageline N isn't going to cut it.
dlaloum
Unless you want to stick to old-world analogue end to end for religious reasons... I would opt for something like the RME ADC with RIAA phono EQ option...
Then you can EQ the cartridge response easily and simply in the digital domain for a flat frequency response - obviously, best results are achieved with a little loading to bring the F/R into the right "zone" - but it is far easier to tune digitally than via loading.
Also note that MC's although mostly insensitive to capacitance, also have their "raw" cantilever performance (including resonance peaks and troughs) exposed - this is where in many/most cases, a better result can be achieve with a properly adjusted MM than with most MC's - you can use the loading to EQ to frequency response close to flat. There are exceptions... things like the Dynavector Karat cartridges... but outside of the exotic end of cantilever construction, all cartridges have cantilever mass in a range where resonances happen in the audible frequencies - and need to be adjusted for
sktn77a
Interesting, I'll have to check that out. I'm not an analog nut - used a SONY TAE-2000ESD all digital pre-amp for many years, but it crapped out on me so I went with the NAIM gear. It's served me well and continues to do so (with the possible future exception of the Stageline N).
Digby
Can you explain the best way to do this?
dlaloum
First you get the digital hardware (ADC) with the appropriate filtering/EQ/RIAA software on board eg: RME ADI-24 Pro SE
This provides both the conversion to digital (ADC), the necessary gain/amplification from the low levels of the cartridge output, and the base RIAA equalisation needed for any records from the 1960's onwards (earlier records may require differing EQ's)
Then you use one of a number of test records, with a pink noise track - record the track, analyse it with the software, and set up digital filtering to achieve a flat frequency response. The pink noise will pretty much instantly show you your frequency response plot - and once you know how it looks you can then set up filtering to adjust it back to close to flat.
I have not used this particular software - but many such have built in automated EQ calculation, where you can just tell the software that the recording is Pink noise, and it will calculate the filters needed...
I did something similar about 10 years ago - but with manually cobbled together hardware and software... which made it hard work, with the release of the RME hardware/software package, most of the hard work is done for you!
Reactions: EJ3
sktn77a
Ah, $2500 for the RME ADI-2/4 Pro SE is getting a bit steep!
Reactions: EJ3
JP
Brookfield, CT
Finding a reasonable accurate pink noise track is a real trick.
dlaloum
LOL - I didn't want to get too far into OCD geekdom!!!
All the pink noise tracks are pretty good up to around 16kHz - above that some of them are iffy... but not hugely so
And with a little research on the topic of pink noise tracks, one can work through that, and get a correcting reference for ones chosen pink noise track...
Reactions: EJ3
dlaloum
I agree - it's not cheap... but then a good phono pre isn't cheap either....
There are more economical ways to do it, there are other software alternatives.... but I don't think I have seen a "turnkey" solution at a reasonable price.
You need a really good ADC... every bit of dynamic range you can get is important.... and they don't come cheap either.
My Mytek ADC cost me circa $1000 about 10 years ago ... and then there is software.
Yes RME is expensive, but it isn't unreasonable for what you get.
In theory, the necessary functionality could be rolled into the Parks Audio Puffin phono stage.... which at around $500 could be a bargain.... but it ain't there... It has the EQ capabilities, but no analysis capability linked to it...
Perhaps if enough people ask for such a feature?
levimax
San Diego
Any of the current ADC's like Scarlet 2i2 which are 24 bit are more that capable to capture anything an LP can throw at it including damaged LP's and it sells for $175. Their mic pre-amps are quiet enough and have more than enough gain for an MM cart, for MC you need a SUT. I use a cheap balanced transmitter with 47K input impedance in front of the ADC to get the right cart loading and use short cables between TT and balanced transmitter to keep capacitance down and do the RIAA and final EQ with free software. It is really quite cheap and easy but not common because of the "TT must be all analogue" superstition some have.
Digby
How are you EQing, for cartridge reponse? What hardware/software do you use to measure this?
JP
Brookfield, CT
I guess it depends how loose one's definition of "pretty good" is.
