astr0b0y
Is that a double-wide?
The only guy that's come here after buying your bits and putting it together himself seems to agree with amir in reference to the safety and noise concerns.
Did you miss that?
Let's put them side by side..,
Mikes best effort
Oh look what a guy with a EE background did..,
That's not the only difference , look closer.Now that I read this over I can see obviously you were lost. Yes that's the picture of Steve's DIY build after he removed the mains filter and used insulated faston's. That's the only difference between the 2. Mine has the mains filter. And I'm using black wire and he's using grey.
The picture Amir used as the dangerous example was that same DAC of Steve's before he pulled out the mains filter and put in the insulated faston's. That's the only difference. Yes it makes the box look tidier without it. But that mains filter was in there for a reason. Not just a decoration.
Ok, so we don't have any examples of a dac you built .. if this is the case what's all this about and why then have you spent so much time trying to defend it.These are both the same DAC that Steve built. Both are a DIY build. Neither was built by me and I never once claimed they were. Only difference is he removed the EMI filter after reading Amir's BS post because at the time he thought Amir might be a real engineer, instead of the competing audio dealer he really is. Very simple. But I know you're just trying to add negativity to the thread hoping people won't actually read the content closely.
Look at the wire coming from the front power button and you can clearly see it's the same DAC.
For anyone who doesn't know here's the thread when Amir trashed Steve's DIY build misleadingly claiming it's our commercial build:
http://www.audiosciencereview.com/f...design-of-diy-originated-audio-products.1865/
That's the picture from your web site too.This is the only commercial build I ever shared on here. It's also the same picture Steve had for reference to look at while building his DIY unit. There's absolutely no safety issues or concerns with this commercial build whatsoever:
You can hardly be held responsible for a build someone else put together with your bits. That's fair enough imo but why all the nonsense.
looks reasonable to me.Yes like I said it's the only picture anywhere of the inside of a Purestream I built. Other than this one which was an early prototype:
No mike, you came out with all sorts of defence when there was no need.You guys ask yourselves why all the nonsense. Great question.
We seem to of got to the bottom of a great deal of it in five posts.
Well mike there's pages and pages a lot of it from you.. you could of just posted this and left it at that.You're just not reading everything clearly.
