I had the house to myself and the day off work, so I dove in deep with Dirac today. Here how the Flex fits into my system:
After first spending a bunch of time comparing crossover points and listening to them, I settled on the LR 24dB/oct at 80 Hz for crossovers. I also put a BW 24dB/oct high pass filter on my subs at 18 Hz. They are only 8" and there is no point wasting any effort down there. The first test was whether DSPing the subs makes any difference. Here are my subs with and without EQ:
And the pic below is what dirac corrected each one to. Ha! EQing the subs was a waste of time other than for learning. This is freaking impressive! I think it's fair to say any differences in this graph are from me moving the mic during the different measurements and process. Dirac apparantly knows what it wants to do with my setup in my room and willl do it no matter what I did to my subs:
This is the uncorrected respose vs the default correction that Dirac does with my system from nothing but crossovers set. I think it's quite impressive and it's quite a bit better than I was able to do on my own given only 10 bands of EQ per channel in the Flex:
EDIT: this is where I come back to this post and mention that after careful A/B listening, the Dirac default curve sounds better than the curve I edited myself. The "flatter" response does not actually sound better. It's barely different, and a little worse. I'll leave the comments in place anyway. By making quite a few corrections to the target curve, I was able to get a flatter response than I was ever expecting to pull off in my room. This pic shows the adjustments to the target curve in Dirac:
Every single point on the curve was confirmed and dialed in over dozens of REW measurements. You don't have to dial in any numbers, just ad points and drag. You can zoom in super close if you need also. I think the interface is pretty slick. The comparison below shows how much I was able to dial it in on my own on top of Dirac:
And because comparisons are fun, below is the original uncorrected response from the image above compared to the final corrected response I was able to get in Dirac alone. I have zero EQ settings in the miniDSP. It sounds fantastic! Dirac was 100% worth the $200. Zero question at all in my mind.
Yep, and this is definitely as loud as I'd ever listen on this system. I didn't test louder because I have no interest in damaging my subs for cool graphs.
I spent many hours on this today, but the final result was generated by:
1. Set delay/levels/crossovers in miniDSP plugin
2. Run Dirac, export correction default curve to Flex
3. Measure in REW and see what it did
4. Adjust target curve, save to Flex, then repeat between this and step 3 until happy (EDIT: this proved to be a waste of time and a worse subjective result)
If I had just done that from the start, less than 2 hours.
Have you tried measuring the sub (by itself with no mains) without any filters in place (no HPF and no LPF)? You are doing some pretty funky stuff with your crossover which is not going to sum well and may be causing your notch (or at least making it worse).
The Revel 105s are ported and have an acoustic 4th order high pass roll off. You are then applying an electrical LR4 @ 60 Hz on top of that effectively making the acoustic high pass behavior 8th order.
Your subs are sealed and you are applying an electrical LR4 @ 60 Hz LPF to them which will not match the 8th order roll off of the Revel 105s. A sealed sub naturally has a 2nd order acoustic roll off but then you apply an electrical BW4 @ 18 Hz HPF making a 6th order acoustic high pass roll off.
Michael
