Where do you see this?
My Flex has this feature but my Flex HT does not.
Found it:
The following software changeLog summarizes the changes made to the miniDSP Device Console (DC). As a reminder, please note that XMOS and DSP firmware are packaged together inside the miniDSP DC and that you may be requested to upgrade your firmware in order to use the latest version of miniDC...
www.minidsp.com
Major SHARC DSP firmware update:
- Volume offset at input before ASRC to solve the inter-sample issue on digital source "2x4HD, DDRC24, Flex, Flex-DL, Flex8, Flex8-DL, SHD series" /
Flex-HT&HTx already implemented this update in earlier
builds.
- Support Vol-Offset "Flex, Flex-DL, Flex8, Flex8-DL, SHD series" to get various sources to match level change
You can see that the Flex, SHD etc., got the update in version 1.1.18 (
note that we are at 1.1.20 now as of today), on Nov 25, 2024, whereas the HT & HTx had it implemented in earlier builds.
Note that it says "support vol-offset "Flex,.....SHD series" but no mentioning of the HT & HTx. Anyway, I opened a ticket on minidsp support and they responded briefly, confirming the HT/HTx had the update in earlier version and the Flex, SHD just got caught up later, but by the time I asked them about the adjustment settings, there has been no response, most likely they went on a two weeks holidays already, so may be some time in the New Year. The rep even suggested that they confirmed there was sonic improvements with the update.
I have since tried listening to some of Adele's, that previously I could hear distortions when she ramped up, now playing through the Flex HT, I no longer hear such distortions, or at least much less obvious. So may be whatever they did, by having input volume control before the ASRC, they managed to reduce ISP related distortions to much lower level if and when such inter sample peaks occurred, may be by a fix amount or something, but without providing adjustable setting via the offset that the Flex/SHD has. But I am just guessing. Will keep you posted if I get a respond from minidsp.
