Mid-to-high end receivers without cooling fans?
jonfitch
Looking through the current products, it seems like Denon, Marantz, Pioneer, Onkyo, Integra, Sony etc receivers all seem to have cooling fans on their mid to high end models? Is Yamaha the only company left that has a fanless design (i.e. the A6A and A8A?). Unfortunately I can't get over the Cyclops aesthetics of the current Aventage line though, hoping for alternatives for a HDMI 2.1 40gbps generation receiver.
If everyone else is using fans, has anyone tried replacing the existing fans on any units with quieter Noctua fans? I noticed a lot of complaints about fan noise on current higher end Denon/Pioneer/Onkyo receivers.
bo_knows
Dallas, Texas USA
Hi Jonfitch,
I have Denon 8500H and I never heard the internal fans. I mean never, and I have had a unit for over 4 years. If they ever kicked in, they were dead silent. My room ambient noise measures 33dB C-weighted and 27 A-weighted. Just saying...
Steve Dallas
A Whole Other Country
Not "high end" but the fans on my Denon 4700 and 4800 never turn on, even when pushed hard.
Dunring
Florida
I use two types of fans, the Nyde Gentle Typhoon are acoustically tuned not to make noise annoying to our hearing. Also the ARCTIC P14 PWM PST and the P12 can run at 1800rpm at the same decibel level others make at 1000rpm. They're static pressure for pushing air through a radiator or filter, and the Nydec are case fans for pulling or pushing unobstructed.
A USB to 2 pin female plug I run from a phone charger to keep the router running cool.
J
jonfitch
Which receiver did you replace the fans on?
