MEIZU Hifi Pro USB-C Phone Dongle DAC Review
confucius_zero
dongle's now discontinued :(
Sinquito
Querétaro
Actually the first seller cancelled my order. I assume that he didn't have it in stock. I tried to purchase another, but it was pretty scarced (on AliExpress). Finally I found a seller that had it and express shipping wasn't crazy expensive (some sellers were charging over 50 USD just for express shipping).
It should be delivered this week according to DHL. Hopefully it will work flawelessly on my Galaxy S20.
confucius_zero
Matias
São Paulo, Brazil
This Clipthat Amazon ad reviews section has a remarcably similar dashboard and readings, don't you think? :)
Shameless photoshopping!
Veri
lystor
I have received two MEIZU Hifi Pro.
Awesome device.
I like it more than Hidizs S8 (Tempotec Sonata HD Pro) / Zorloo Ztella MQA / Zorloo Ztella because I have problems with them in Windows 10.
Veri
Awesome device.
I really, really like the meizu dongle too :D Only negative is that sound sometimes(rarely) breaks up. due to synchronous transfer (not async).
milus
Awesome device.
@lystor
Would you mind telling where did you get it from?
I thought it was discontinued.
ad_fletch
Australia
I got from here but looks like only standard version available - but a bargain! https://www.aliexpress.com/item/4000375291843.html?spm=a2g0s.12269583.0.0.5f711bfdyqDEFd
Yeah I did fairly thorough Aliexpress search on the weekend and came up blank for the Pro. Last remaining sources seem to be on eBay for over $50 and Giztop for $40 plus postage. I went for latter option - hope Giztop comes through (seems to have same mixed reviews as Banggood, Gearbest et al).
mslim
I thought DAC didn't make much difference to the sound but this Meizu Pro I must say doesn't sound good.
Using on Xiaomi Note 7, playing audiophile vocal FLAC via build-in 3.5mm jack vs USB-C Meizu Pro, both using USB Audioplayer pro. IEM - AKG tuned Samsung IEM. The Meizu sounds nasally (for female vocal) and 'boxy'. I can't believe myself trying to describe the difference having previously frown upon this. A bit more high pitch also in the higher frequency compared with the build in 3.5mm jack.
Jimbob54
How did you ensure volumes were matched between the 2 devices ?
mslim
Plug in USB-C dongle, play music; unplug the 3.5mm from the 3.5mm end, plug in native 3.5mm and play. Vice versa. I guess that's all. The immediate difference was apparently. I have no idea what the output impedances are for each and their effects. The ? tonality/ ? timbre changed. I'll try a bit more this few days but I dread describing how they sound. Better to just say better or worse than native.
Jimbob54
In no way shape or form will that be level matched. You're not comparing apples with apples. I guarantee if you measured the outputs electronically from both outputs using a test tone, there would be a noteable difference. You need to be within a fraction of a dB to really compare. Whole dBs off and you're potentially in a whole different ball game
Sinquito
Querétaro
Most likely you are now hearing the real tunning of the Samsung earbuds. Those are not good sounding iems, imho, I had have the ones from the S8 and S10 and never liked them. Get some Etymotic if you want reference sound (ER4SR/ER2SE).
