- Joined
- Oct 25, 2019
- Messages
- 11,110
- Likes
- 14,773
Correct. It is. I'm not sure what other response you might be hoping for.Hey. My DAC produces clicks and pops when using 4G mobile internet. I use a Xiaomi MI 8 light phone. This is a problem ..
Sorry I totally misread your post and thought that the low range was because your headphones were too much efficient and volume was very high basically all the way.
Sorry didn't mean to be rude.
Other members have already suggested the extension trick, which unfortunately doesn't seem to help. My suggestion of using the Apple dongle still applies though, it's extremely inexpensive and if you can get the US version I think it will work wonders since you already have UAPP. I have the N5005 so I can give it try with both dongles using a Galaxy S20+, but I'm a quieter listener, so maybe enough volume for me couldn't be enough for everyone.
Yes, I'm sure, but I think that the trick didn't work for @WondrousHippo and even if it worked, it could be less convenient?
I think the n5005 are 8 ohms or close to that. I have a small Beyerdynamic extension for smartphones cases. I can give it a try.
Headfonia just put up a review
https://www.headfonia.com/meizu-hifi-audio-pro-review/
Something weird though. On page two, they describe the Apple USB-C dongle as achieving more volume
"Apple’s $15 AUD is both an affordable and capable alternative to the headphone jack, and makes for a compelling proposition for the wired listener. It actually sounds louder than the Meizu at any given volume level when switched between devices..."
Based on a Amir's measurements of both devices, shouldn't the Meizu be capable of driving headphones to noticeably louder volume? At least, that's my personal experience.
Does seem odd.
More baffled that they are reviewing something that doesn't seem to be available anywhere anymore.
Hopefully they are getting more. More likely they've had it a while and only just got around to testingYeah. They say they got the dongle from Hifigo. I do not think they have had stock for a few months now.
Hey, it looks like Meizu has a new thing on their US Amazon store. The "Meizu MasterHIFI." Anyone know if this this just the same as the non-pro version of the old product? The forum has literally zero search results for the new product name, and it's not listed at all on their official website, though the specs on the Amazon page for the MasterHIFI match the specs for the Meizu Hifi Pro on their website. I'm suspicious because it's a lot cheaper...
For IEMs or on the go I use the cheap as hell apple usb-c dongle. With work laptop I use the meizu dongle but if I'd had to buy one now, I would save up and buy an E1DA 9038d. Amir should review this single-ended version of the 9038s some time looking forwardSo what would be the recommended replacement since the pro version is currently unavailable on aliexpress?
