Has anyone tested SQ face-to-face with one of those flagships mobile DAP like DX220, or M11 or even one A&K please?? Is it far far away??
Hi
@Nango
The below was meant to be a shorter comparison but ended up being a mini-review... anyway on with it..
I have a lot of different equipment and headphones that I've done many many A/B sessions with different combinations.
My favourite is the ADI-2 DAC with Fostex TH610's with +3.5db bass at 65hz and +1.5db 6.5kHz w/ sharp filter using Roon for playback.
The sound is effortless, transparent, powerful without being bloated with a very sweet and extended high-end that's not brittle or harsh.
I would say the ADI-2 DAC is very natural and neutral sounding and the most musical and involving. I can listen for hours without any fatigue and at higher levels than any other combination.
You have to be careful about this, the sound is so clean, smooth and powerful you can easily forget how loud you're listening, which is obviously not good for long-term hearing!
For Comparison I have:
iBasso DX220 with AMP1mkii (stock) AMP8 (balanced 4.4) and AMP9 (Korg Nutube)
FiiO Q5 with AM3A (stock) AM3B (balanced 4.4) and AM5 (high power 3.5)
RME ADI-2 DAC fs (Gen1)
I use them with;
Sennheiser HD600 w/ litz pure silver balanced 4.4mm and litz pure silver 3.5mm cable
Sony MDR-1A DAC Phones in passive mode w/ stock cable bypassing Sony DAC
Campfire Audio Andromeda w/ litz pure silver balanced and stock litz 3.5mm cable
Fostex TH610 w/ litz pure silver balanced 4.4mm, litz silver 3.5mm and stock 6.5mm cable
Sony WH-1000xm3 and Samsung Galaxy buds for travel
https://flic.kr/p/2gq8gRK
The DX220 is a very good DAP - The AMP modules are also all very good with there own sound signatures but I think the dual Sabre 9028Pro DAC implementation still has a little bit of that Sabre Glare that people talk about which is not a problem on any of the head phones except the Fostex TH610 which brings that glaring Sabre top-end out a bit too much. The stock AMP1mkii module (unbalanced) having less power than AMP8, is not able to drive the TH610 as well or the HD600 either.
2pin2mmcx-th610 by
Hilton, on Flickr
With the AMP1mkii running out of puff (unbalanced), the AMP8 steps that up, but in doing so also has a little more sparkle that can get fatiguing on the TH610, though with HD600 it is fine and it drives them cleanly and easily. The Andromeda's sound wonderful with their very sweet top end and powerful low-end on just about anything, the only thing that varies is the amount of low end bass and hiss and maybe a slight variation in midrange but that's probably just because different DAC/AMP combinations roll-off or boost the two extremes of the frequencies.
The DX220 sounds a little more energetic and dynamic at first, but I still prefer the ADI-2 DAC with a light bass and treble boost (as noted above) which brings a little more of a more natural dynamic back without making it harsh or fatiguing.
DX220 with AMP9 Korg nutube is a very interesting combo.... It obviously adds a little bit of tube distortion and rounds off the sabre glare really nicely. With Andromeda's the hiss is definitely present on AMP9. Not a problem with IEM on the ADI-2 DAC. Andromeda's are just about my favourite phones right now with the TH610 a very close almost tie. Problem with IEM's as they get a little fatiguing and sore ears after a while, where as the TH610 or HD600 you can wear for hours. The TH610s arent as tight as the Andromeda's in the bass region but sound is more like a good pair of full range speakers cranked up.
I haven't spoken much about the HD600 or MDR-1As.... The HD600 are just wide, deep, clean and smooth and natural on the DX220 w/ AMP8 or ADI-2 DAC. They lack the bottom end of course but for orchestral or acoustic and vocal Jazz there's not much better out there.
The Sony MDR-1A are just fun POP headphones with that Sony house sound that exaggerates the midbass and they are actually very forgiving. They are not particularly resolving but for highly compressed loudness wars type pop music they just groove along nicely.
The FiiO Q5 with stock amp is a very good clean amp, it's also using a dual AK4490EN DAC setup that sound very similar to the ADI-2 DAC.
In fully balanced mode with the AM3B AMP module it's my second favourite combo and again there is a little more punch and sparkle but I think that's due more to the AMP module than the DAC.
So you probably noticed I talked more about the headphone sounds a lot and that's because the headphones make way more difference than the source, DAC or AMP.
Having said that though, it is clear the ADI-2 DAC is a level above the DX220 AMP8 / Q5 AM3B combos.
ADI-2 fs by
Hilton, on Flickr
I would go so far as to say the ADI-2 DAC fs is "perfect" and it's exceeded my expectations by a long way.
I started out with HD600's 20 years ago with Sony high-end ES Receivers (yes the same pair I use today that are in as new condition with new pads)
Music has never felt more real and in the moment than with the ADI-2 DAC with TH610 pumping along and I enjoy the combo more than my home system for the first time ever.
For reference I still use a Sony DA5200ES receiver with 6 x floor standing Sony SS-X70ED mains/surrounds and SS-CNX70ED w/ 2 x Velodyne 10" subs that I love the sound of in 2 channel direct mode or in 2.1 and the TH610 with ADI-2 DAC sounds the closest to the speaker system sound that I prefer but cleaner and punchier obviously because you're not dealing with room 'modes' and influences.
In-wall speaker back together! by
Hilton, on Flickr
Here's my room corrected sound of my home system to give you an idea of what I like sound wise. I believe in touching the signal as little as possible with DSP and just taming room modes and blending the Subs in nicely with the mains.
I use JRiver with hand crafted DSP correction based on REW measurements.
1-24th-smoothing by
Hilton, on Flickr
TH610 response from Innerfidelity.
TH610-innerfidelity-FR by
Hilton, on Flickr
I want to say a special thanks to
@amirm for all the extensive testing and retesting of the equipment on the forum, I've found it very interesting and I've read both of the ADI-2 DAC threads from start to finish. You're also a top lot here!
I would also say that the empirical evidence stacks up very nicely with what I prefer/hear, though I'm obviously subject to confirmation bias, I love the ADI-2 DAC as a desktop solution, something the DX220 did very poorly due to lots of issues with the XMOS usb drivers being unstable and lots of dropout issues. But for an all-in-one portable solution the DX220 is rock solid. The ADI-2 DAC is very robust on USB even through a USB hub.
My Samsung Tab S4 and S10+ phone don't drive any of the headphones particularly well which is why I have the DX220.
The ADI-2 DAC also works very well with Android tablet OTG using USB Audio Player Pro giving full samplerate/DSD support as well as full Tidal support via USBAPP.
I'm flying in and out for work every week and the ADI-2 DAC comes along for the ride in my carry on and is setup in my hotel with Android tablet driving it perfectly. It also gets used for gaming and whenever at my PC.
At some point I'll get around to setting it up with a couple mono blocks as a dac/pre for 2-channel in media room and w/ my desktop speakers w/ mono blocks.
I use the DX220 in the office and occasionally when out and about with Andromeda's or on the plane with Sony 1000xm3 in LDAC mode.
I use FiiO Q5/AM3B around the house mostly when moving about and doing things as opposed to being in my office/media room. (bluetooth to mobile or sometimes OTG stacked in pocket)
Overall if I could only choose one device now, I would definitely save up for the ADI-2 DAC it's a marvelous piece of engineering easily surpassing all my portable gear. Measurements prove that out, and to my ears it's also pretty clear that the top-end is much sweeter and the bottom-end more natural.
