Measurements and sibilance
Doobrey
I have noticed with a few different dacs I own and tried that some seem to exaggerate or dull sibilance. It’s made me wonder what’s going on to cause this issue, is it as simple as the digital filter type or is there something deeper within the measurements that would make sibilance such an issue on some dacs?
Were these side by side comparisons and did you match levels? Level differences can make sibilince seem more or less. Yes, depending upon the filter that might influence it as well.
please tell us each one and what you think you are hearing with each.
Sibilance is usually something between 6-10 khz. So differences in frequency response could cause a difference in what is heard. An early and slow roll-off filter might be heard this way if one were to key on sibilance in the upper part of that range.
If too many DACs do that I would look at the speakers,their placement,room,etc.
DACs are ruler flat for decades now,this 4-10Khz range who causes this problems must be observed carefully before buying speakers,to some people (me amongst them) this is a torture ,specially an elevated 4-6Khz and more so combined with a thin midbass which strangely seem to correlate.
