Maximum subjectively preferred loudness level
sarumbear
Perhaps when it starts citing references we'll then be able to check.
You maybe missing my earlier post. There are no references when writing code. Nor there are for passing the bar or MBA exams. In those cases where the procedure is important ChatGBT delivers. It is not the knowledge but the use of the knowledge...
Axo1989
Sydney
You maybe missing my earlier post. There are no references when writing code. Nor there are for passing the bar or MBA exams. In those cases where the procedure is important ChatGBT [sic] delivers. It is not the knowledge but the use of the knowledge...
ChatGPT doesn't have semantic knowledge. It is built on patterns of proximity between word-tokens in a very large corpus of text. Per my previous link:
... McCoy and Ullman explain that “the word ‘dog’ is represented as the vector [0.308, 0.309, 0.528, ?0.925, ….]”. If you plot that into a coordinate system, then words that often co-occur with “dog” in the training data will be positioned close to “dog”. This “map” of how words are related to each other is also called the “vector space” or “latent space” or even just “space”.
Once GPT-3 is trained, it doesn’t “know” anything about its training data any more. All it knows is those coordinates. Dog is [0.308, 0.309, 0.528, ?0.925, ….], and that …. stands for a lot more numbers. It also knows what other words (or tokens) “dog” is close to. All those tokens and their coordinates across billions of different parameters make up the “latent space” of the model.
If you think about it only in terms of how humans understand semantic concepts, then your analysis will be orthogonal to the operation of the generative text tool.
sarumbear
Which is what I said: "It is not the knowledge but the use of the knowledge..."
Axo1989
Sydney
Maybe we are saying the same thing, I didn't get how that statement was meaningful except in vague terms?
sarumbear
I am using "forum language" :)
