restorer-john
Speakers are higher priority ATM.
Where do you think they are going to land price range wise? Under AU2K or 2-3K?
Probably a couple of months. Speakers are higher priority ATM.
TBC but more than thatWhere do you think they are going to land price range wise? Under AU2K or 2-3K?
Yep. Should make their first appearance at the Sydney hifi show in April.u building speakers too?
Using Purifi speaker drivers?Probably a couple of months. Speakers are higher priority ATM.
YesUsing Purifi speaker drivers?
Cool. I’ve been waiting for an implementation. They look weird but looks aren’t everything!
Hi @SparkyI wonder if I would benefit from a pair of these?
I use a Cyrus Stereo 200 power amp into an RME ADI2 DAC using Spendor A7 speakers.
These Purifi amps are really intriguing and seeing how they measured is something else altogether!
Any thoughts @March Audio
Is that a “Gainclone” amp?That's for show. When you buy one, this is what you get!
Hi @Sparky
I have not heard the Cyrus so it's difficult to tell, however it won't compete technically with the Purifi P451. I can't find a good set of measurements, but Cyrus spec states 0.1 % thd + n ( 60dB sinad) which is very poor. P451 is way ahead at 104dB (0.0006%).
The P451 is also more powerful and will have better current capability but your Spendors are not particularly difficult loads. Dipping to around 6 ohms. The phase angle excursion at about 70Hz isn't so pretty, but it has a reasonable 87dB sensitivity.
Hope that helps
@Sparky Found some measurements.Hi @Sparky
I have not heard the Cyrus so it's difficult to tell, however it won't compete technically with the Purifi P451. I can't find a good set of measurements, but Cyrus spec states 0.1 % thd + n ( 60dB sinad) which is very poor, but probably just where they have taken the rated power measurement.
Hope that helps
@March Audio
It really does help! Thank you so much!
I wish there was a way to download your knowledge into my brain as it's impressive.
Looks like the Cyrus is going on eBay...
Are you considering any significant upgrades or changes to the design before I look into buying?
I wouldn't want to spend this sort of money only to find you've overhauled it in a month's time!
I ask that question with the best of intentions and mean no disrespect.
I know I have a vested interest here but the more I look at the Cyrus performance the less impressed I am.
Hi @ironhorse128
I will double check and remeasure (probably tomorrow) but 16 watts isn't far off, might be a bit lower nearer 12 watts.
To be clear this is switched on but no music playing. That's actually very efficient.
In standby its around 0.2 watts.
My general recomendation is not to leave any electronics like this on permanantly. You just life the capacitors more quickly for no gain in sound quality, plus of course waste electricity.
Btw we have just implemented 12v trigger functionality on the control board if that helps.
@March Audio
What is the idle power consumption of one of the P451? I am curious as I am planning on buying two and I heard that the idle power consumption might be up to 16 watt.
