Need some help to get the most out of my system especially for 2 channel music. (I also use Party mode)
MP-60 + Oppo udp-205 + WiiM Pro + Shield tv
What is the best way to connect this system for Music listening with the WiiM?
I would like to make use of the Oppo's DAC for the WiiM instead of the MP-60 DAC.
Currently the WiiM is simply connected with Coax to the MP-60 and the Oppo with HDMI to the MP-60.
The Oppo has a myriad of in/outputs but the MP-60 has no analog inputs.
Any suggestions are welcome and appreciated.
Read the threads about inexpensive vs. high end DAC performance on ASR before you reject the advice below.
If you are using any sources with native digital output, use their digital output and forgo using their "better sounding" DACs.
If you need an analog input for your Lyngdorf, get a high quality A to D. I use a mini DSP Flex in my system, but there are other options available.
Question: What does the WiiM provide that the native streaming capability of the Lyngdorf doesn't provide? I use my Lyngdorf processor as a Roon endpoint so I haven't explored this topic, but I would be surprised if you need the WiiM.
