I agree. I own both, and while I used both EQ and Dirac with a sub on both versions, I still found the Meta version noticably better. Smoother, less strident, more natural and easier to listen to in the presence region. I personally think it's more about the off axis reflections which seem nearly perfect with the Metas. They just seem smoother and more natural to me. The OGs while very good, just seem a little bit off by comparison, and I found that noticable immediately. When you live with speakers for a while, subtle difference just aren't all that subtle, at least not to my ears.Pablolie keeps repeating everywhere in this forum his believes (like denying the audibility of such wide presence region deviations) and misunderstandings (like reducing a speakers behaviour to a single PIR) while not owning both.
The facts are like others also wrote above different, they have both significantly different on-axis responses (3-4 dB at a wide presence region are very audible, different directivities and different distortion rise especially at higher levels.
I own both of them since each generation was released and even had provided some in-room measurements (which are similar to the corresponding PIRs) and an EQ to match those which he could have tried listening instead of denying that such wide deviations are inaudible. I cannot stand listening to my original LS50 without anechoic based EQ above 500 Hz which is something fixed on the Meta, also at higher levels the original ones get quite "muddier".
Exactly. I don't understand people who ignore listening tests. Measurements are important, but our ears are the final judge.I agree. I own both, and while I used both EQ and Dirac with a sub on both versions, I still found the Meta version noticably better. Smoother, less strident, more natural and easier to listen to in the presence region. I personally think it's more about the off axis reflections which seem nearly perfect with the Metas. They just seem smoother and more natural to me. The OGs while very good, just seem a little bit off by comparison, and I found that noticable immediately. When you live with speakers for a while, subtle difference just aren't all that subtle, at least not to my ears.
Mirror, mirror on the wall... off into the ignore list..... trolling ...
Said nobody else. The whole premise of this website is to dispell the myth that our ears triumph over measurements. Then again this thread shows that the force of subjectivism is strong with some.Exactly. I don't understand people who ignore listening tests. Measurements are important, but our ears are the final judge.
The differences are similar to the ones the ASR measurements and mine show.Mirror, mirror on the wall... off into the ignore list...
Here's what another troll, John A, measured in Stereophile... :-D Oh yeah, vast differences in the presence region... [the original LS50 is in blue]
Some conclusions in the measuring tests there: ".. The two models offer identical in-room responses below 300Hz. There are two small peaks and dips that have not been eliminated by the spatial averaging, and the midbass region is shelved down, though the extension is helped by the lowest-frequency mode in my listening room ..Like the Anniversary Edition LS50, the LS50 Meta's cumulative spectral-decay plot on the tweeter axis (fig.10) features astonishingly clean decay at all frequencies .. "
The only difference, JA basically states, is ".. Both speakers have a little too much in-room energy in the upper midrange, but the Meta's response is flatter in the presence region and there is a little more output in the high treble than with the Anniversary Edition ..". Clearly minimally so, though, if again you check the graph, but you can hear whatever you wish. Oh, you already do.
Nope. not any measured evidence of big differences.
And even then especially at this region such difference is easily audible.Hmm unless one's hearing is deteriorating, 3-4db difference is very obvious...
…and those audible differences can probably turn to almost* zero if one uses the PEQ funktion in a WiiM pro with the old ls50.And even then especially at this region such difference is easily audible.
To hopefully finalise this tedious discussion here is also a direct audio recording comparison of both where despite the not very discriminating music samples used the audible difference is really obvious and in accordance to their measurement differences:
The differences can be significantly reduced but not made to really zero as the distortion and also crossover frequency and slopes are different which results also to a different directivity, I own both since they were released and had written more about them here.…and those audible differences can probably turn to almost* zero if one uses the PEQ funktion in a WiiM pro with the old ls50.
Good news for those who have that older model.
*( In the new Meta ls50 they use another crossover with possible other steepness in topology - that also makes a small difference and this cant be bettered with PEQ.)
Looking at your measurements, It looks like the Meta have a slightly better drive unit with slightly less distortion, true.The differences can be significantly reduced but not made to really zero as the distortion and also crossover frequency and slopes are different which results also to a different directivity, I own both since they were released and had written more about them here.
Yes, more and better insights and comparisons can be found in the corresponding white paper https://assets.kef.com/pdf_doc/LS50WII/KEF-LS50Meta-LS50WirelessII-WhitePaper.pdfLooking at your measurements, It looks like the Meta have a slightly better drive unit with slightly less distortion, true.
That is what the marketing white paper says. And if you don't think KEF wants to push you into an upgrade cycle, you are a tiny bit naive, taking manufacturer collateral material for ultimate truth.Looking at your measurements, It looks like the Meta have a slightly better drive unit with slightly less distortion, true.
And all 3rd party measurements also confirmed.That is what the marketing white paper says.
Yes, especially in that region (and actually more 2-4 dB), you can test it yourself with the recording posted above.At least KEF are consistently honest about their measurements.
Is 1-2db even audible with pink noise, let alone actual music?
