Looking for speakers with a spacious sound and great timbre?
music_lover
Hello, I am looking for speakers with great timbre. I come from headphones. I find the HD 600’s timbre to be great. So I am looking for something like that in speakers . I also want it to sound spacious and airy. My budget is $1500. I don’t mind active or passive.
Being in the UK, I'd initially have suggested one of the 'BBC derived' family of speakers, current examples of which usually offer great natural midrange timbres at least and a good perceived soundfield as pair matching is pretty good. Prices are now silly-high on almost all of them, as their markets will happily pay this money it appears. For used ones, Harbeth SHL5s or C7s from the noughties might be obtainable used for around this figure but as they sold for more in the US than in the UK, this may not apply and both these have the kind of gentler perceived balance the HD600's have (from memory).
I don't know current KEFs, but the Meta ones seem slightly 'calmer' in the mid high frequencies and this may push the listener's attention back to the midrange a bit more. I've not heard any to confirm though. The Wharfedale Linton Heritage including stands looks to be in your budget and despite the 1960s styling, appears to be a bang up to date in sound quality and overall performance.
Of our active favourites here, might Neumann do better here as I gather the balance may not be as as 'bright' in a given room as Genelecs are reported to be (I'd suggest it's dispersion rather than on-axis response)? I wish I could get to hear some to tell you definitively as on-axis response doesn't tell the entire story once these speakers are used in a typical *domestic* room with heaven knows what acoustic. DSP can help here though to tame excesses and maybe gently eq the balance to suit and of course most actives worth their salt have some bass and hf correction switches on their backs to help..
LS50 Meta
Thanks for your reply.
What Neumann would you suggest?
Whichever model your budget would allow and of course taking into account the post above by @Sokel
The Neumanns I was thinking of (80 or 120 II if possible) WON'T and weren't designed to fill a large room, but as a near-ish field (1 - 2m listening distance and maybe 3m at an absolute pinch if you don't drive them flat out), they may be fine. However, if you like larger scale orchestral or techno music genres, a sub or two would need to be added (or a much larger speaker able to go louder more effortlessly), but I'm complicating things too much.
I don't know how different they are from my R3 og, but I would describe mine as anything but "spacious" in sound
They are different. I have the original LS50's and with a little EQ to deal with the bump at 2.5 kHz they are spacious.
Really? Why not? How would you describe them?
I certainly find the KEF LS50 speakers have excellent timbre, and seem to do space well, as one would expect from a stand mounted coax speaker.
I might be biased, but I really think their 3 ways are noticeably better than their 2 ways. The dome mid they use is one of the finest midrange drivers available, right up there with ATC and Bliesma. Add to that their excellent tuning and you're in business.
I'm also a big Sennheiser HD600/650 fan.
I feel like Wharfedale has a sound that is reminiscent of the HD650 for me. Some ELAC Andrew Jones offerings like Debut Reference and Uni-Fi as well.
Were you looking at standmount or floorstanders?
Speakers with wide dispersion like the Ascend Acoustics Sierra 1 V2
I push mine w/Toppings PA-7+. Spacious and airy like my ProAc 1SC but with a lot more ’body’.
Run ‘em on valves also quite well. Quality build and performance well beyond their price which is
a bit over your budget. They come on sale several times a year if you are patient. The tweeter and
midwoofer are really well integrated, and can go really quiet loud for a two way w/no breakup. The
tweeter is a honey. Not as much ’charachter’ as the 1SC but a better value and easy to integrate w/Rel
subs. Good luck…
The Sierra-2EX V2 would be my pick.
You're just not gonna get as wide a radiation using dome tweeters:
Again, I don't have LS50 and have never listened to it, I own R3 og, and they definitely have great tone, good bass extension, accurate reproduction, but in all honesty don't describe them as "spacious", I don't feel like They fill the space better than many other casual speakers I've owned
