Diocletian
- Joined
- Mar 8, 2025
- Messages
- 9
- Likes
- 1
- Thread Starter
- #21
I can get the sb-1000 pro for around 900$ here. As I said I can stretch the budget but I've always been more inclined to buying more music than better gear. Maybe i can pair the wiim ultra with the fosi za3. I read good reviews about it.SB-1000 Pro is available costing a little more and being a bit better. A-S 501 is fine I have A-S700 and old R-N402D. WiiM ultra isn't really more versatile other than HDMI ARC input, it still doesn't work as USB DAC. Don't skimp too much on sub as you will have controls just for one.
In Spinorama there is a score without/with sub and same with EQ so that isn't hard. In generally you should watch Amir's videos about measurements and how to interpret and understand them on YouTube and don't worry it will all come in it's place, just give it time.
Placement is crucial and you are welcomed getting measuring microphone and starting to do your own measurements and EQ-ing.![]()
Audio Science Review
Technical Reviews, Discussions and Measurements of Audio Products. This video channel is an adjunct to Audio Science Review website which contains the same.youtube.com
Feel free to ask anything that you think you don't understand and welcome to ASR.
Ok will look into these. From what I can understand looks like i should aim for more neutral speakers. Any passive speakers that fit the description?Music like that will produce a lot of distortion but will also mask a lot of distortion. Still, since you don't need high levels and low bass may be detrimental in you living situation, consider some smaller but tonally very accurate speakers with low distortion. Since with the Wiim you need a separate amp, consider some active speakers. Some very good ones are studio monitors. The Genelec 8030C from 478.15€ per unit here, Neumann KH120II from 612.61€ per unit here or Genelec 8040B from 755.46€ per unit here fit into your remaining budget.
Yea I know, but nothing I can do about it. My whole collection is filled with those kinds of albums and wouldn't change a thing. If anything I would get more when I had the chance before the prices skyrocketed. After all a good record is subjective. For example the Mgla you posted doesn't sound very interesting to me but I used to like them 20 years ago. Yea my budget is around 1.5-2kNo offence but it's rather badly recorded underground and the main problem here are records, not speakers.
From classics such as Darkthrone to some Eastern-EU stuff like Mgla
There's a lof of good records.
Even Wes Borland's crazy stuff like that:
If you don't have ~$1.5-2k to spend I'd suggest get a pair of good headphones.
