Diocletian
- Joined
- Mar 8, 2025
- Messages
- 9
- Likes
- 1
Hello,
New to the forum (sorry if this is the wrong place to post this) and to hi-fi in general, even though I've been collecting Lp's mostly and CDs/MCs for almost 30 years now. I am looking to upgrade my system and I've searched this forum for similar posts. Altough I found a similar post, the music I usually listen to is much heavier/faster (than Accept, Maiden or Metallica that has been posted) and since half the people say that music doesn't matter in regards to your hi-fi system and the other half that it does, I decided to ask for recommedations.
I am currently using a rega p1+ and edifier s3000pro active speakers which I am happy with. I am looking to move the edifiers to my pc and get a cd player (havent had one for 15 years or so), a set of passive speakers, and an amp to drive them.
90% of the time I listen to death/black metal. The blastbeat heavy kind. Bands like Truppensturm, Black Witchery, Diocletian, Conqueror, Antaeus, Incantation, Infernal War, Marduk etc
My listening room is around 15-20 sqm and the ceilings are 2.7m high. The listening positions are slightly to the left (or even further left) of where I intend to place the speakers with a distance of around 2.5m (less if you sit at the end of the L shaped couch).
My budget is around 1500 euros.
My questions are:
. Can anyone recommend a speakers/amp system (+cd player maybe) within my budget? Bear in mind that I live in Greece and some brands might not be available.
. Is it possible to plug the TV to the amp aswell and use the hi-fi speakers for it and get rid or my dali katch one soundbar? Should I add a central unit later and/or a subwoofer?
. What should I look for in your reviews database? I am not very technically proficient about hi-fi and don't know that to look for in the graphs. What makes a speaker good for the music I enjoy?
. Do I need a dac or a sound card in order to use the s3000's on my pc or it wouldn't make much of a difference?
Examples of bands I listen to:
Godless North - Dark Rites of Mystic Order [Full Demo] 1998
Diocletian - Infernos
Infernal War - Into Dead Soil
Thanks in advance
My questions are:
Thanks in advance
