Linkwitz LX521.4 - new build and impressions
Guys, have you turned your bass modules at different angles? Pointing dipole null and backwave should have a very drastic effect on bass modes and reflection nulls. Distance to front wall is most critical anyway, listener to backwall comes second considering nulling.
https://www.hifizine.com/2011/09/prototyping-dipole-bass-system/
https://www.hifizine.com/2012/03/on-dipole-subwoofer-placement/
Siegried and others involved with the LX521 suggest angling the bass modules to tame room modes. I will be experimenting with that.
There are two gigantic woofers on the bottom responsible for sub-bass. Definitely don’t need them.
Ugh. "Definitely"? Just because there are two large woofers? Now, if it happens that you own these speakers and are talking from your personal experience, then please clarify this, so that I won't be invited to ask you whether you've wondered why it is that with the great majority of low-frequency loudspeakers, subwoofers especially, the drivers are mounted in some type of enclosure. Contrary to what you imply, the mere existence of two big sub drivers is not, in and of itself, a guarantee of adequate deep bass.
Okay, the lower unit that houses the two woofers is basically the same unit that is advertised as the low frequency extension 'upgrade' for the LXmini (LXsub4, here).
If they're selling these units to extend the LXmini below 50Hz, then it's definitely enough in the LX521.
I do own a set of these, and I also have a home theater setup with a relatively large subwoofer. What I can say is that for the vast majority of music, the LX521 in a correctly sized room with placement as prescribed do not need a subwoofer. You are able to see significant movement in the woofers if low frequency signal is present, so it’s possible to see if they are trying to produce low bass and are failing. One thing they do not do as well as a large sealed box is giving the tactile sort of pressurization from the loud bass. They can play loudly, and they can product a lot of nice bass, but there’s something a little different about how it feels on your body. I have not been able to figure this out with in-room measurements, but remain eager to learn more about that.
They do need at a bare minimum three feet of space behind them, but work better with five. I have been able to shoehorn them into an 11x16 foot room with acceptable quality, but they do significant benefit from being set up in a room at least as large as described by the designer, I believe 180 square feet is the minimum.
I am not sure what to say about the ground loop problem. I use the RCA outputs of the 4x10HD and have no issues with hum or buzz.
Sheesh. Twice you have used the word "definitely" when saying something that was barely more than a guess.
The LX521 can extend to 20 Hz, and that is the definition for me of what a subwoofer should do.
Whether they would have an even sub-bass response at 120 dB SPL in a live concert is not my criteria. Neither is the distortion. Sorry for the confusion.
Hi all,
One of my COVID projects was to build the Linkwitz LX521.4 to replace my first LXmini. I finished them last week and hooked them up to Nord-built Hypex 4-channel amps and a MiniDSP 4x10HD. And Yes, I know these things are ugly. I had put off building them for some time for several reasons: (1) cost; (2) uncertainty about whether they would be too visually obtrusive; and (3) ugly. But COVID made me say, What the heck, just do something already. So I did. I don't think building them out of pretty wood makes them appreciably nicer looking, so I just ordered the Madisound Baltic-birch kit.
I've had the weekend to listen, and I just want to report that these are, hands-down, my favorite speakers ever, including the Dutch & Dutch 8C, which I sell as a dealer and think are awesome. Of course, by the time you've built the LX521.4 and obtained the 8- or 10-channel amp(s), 4x10HD, and decent cabling (copper speaker wire, a bunch of XLR's, 6 or 8 male and female Neutriks, etc.), you'll have spent about $6,000, give or take, so it's not like you're getting off cheap, but what a payoff.
If anyone knows why, I found I couldn't use unbalanced RCA connections from MiniDSP 4x10HD to the Nord amps without ungodly ground loop noise. But once I switched over to balanced connectors using the Phoenix pigtails supplied with the MiniDSP, the noise went away entirely. I've got two separate Nord amps, one a year old, one new, and the older one had no problems running unbalanced to my prior LXmini. I can't figure how this new build created a ground loop.
Congrats! I've always wanted to listen to these. They're definitely funky looking speakers, but FWIW my hipster brooklynite self is a fan of baltic birch and would take it over many fancier woods aesthetically anyway :)
You're just anal-trolling a thread yet again.
This speaker (LX521) has been available for nearly ten years now and the dipole woofer concept around much longer than that. It is all extremely well explained on Linkwitzlab.com. I suggest to take some time and read up on the topic.
One of numerous pages available for your edification:
http://www.linkwitzlab.com/LX521/Description.htm
Dave.
Never had the privilege of hearing these, but I trust the ears of the late Peter Aczel. These are Sigfried Linkwitz's gift to audiophiles everywhere, and, for what you're getting, a real bargain. Now if you just used little grill cloth on the woofers, their appearance could be greatly improved. Even more so if a way could be found it make the top drivers some other color than black.
There is a vendor called Magic LX521 who will finish these in whatever wood or veneer you want. They even offer to do them in Panzerwood!
Thanks for a response from someone who actually owns these speakers. The comments I've seen from different users over the years, with both this speaker and its predecessor, is that the deep bass is probably not adequate to satisfy people who want home theater level of bass, but adequate for people who listen to music. I would be in the latter category, however I do sometimes listen to music where the deep bass is an important part of it and it wouldn't sound very satisfying if the deep bass wasn't fully present and accounted for.
For anyone who isn't thoroughly familiar with the history, the predecessor of this speaker, the Orion, first came into prominence thanks in large part to the praise heaped on it by Peter Aczel, the publisher/editor of The Audio Critic. Criticisms of any speaker design are often based in the understanding of the theoretical distinctions between the given design and more conventional designs. As such, the criticisms of the Orion and the LX521 are generally twofold, and are essentially the same as with any other dipole radiator (or any speaker that approximates a dipole radiator). Some people question whether it is desirable to have so much acoustic energy reflecting from the wall in back of the speaker. Linkwitz obviously believed that this is to be desired, and while he did also mention that the radiation pattern avoided much of the side wall reflections, this benefit seemed sort of secondary, at least less important than the strong desirability of the late reflections from the rear wall, and he emphasized the importance of tonality match of those reflections to the direct wave.
The other criticism that is based in the theoretical understanding of the design approach is with the fact that as frequency moves lower and wavelengths get longer, the cancellation between the front and rear wavefronts increases. I recall that he wrote that the cancellation yields a bass rolloff that increases at -6dB per octave. But I suspect this is fully correct only for a middle region where the wavelength is not a whole lot shorter than the baffle width and not a whole lot wider than the baffle. At frequency high enough to where the tweeters are highly directional, there will not be appreciable cancellation between the front-facing tweeter and the one facing the rear. For upper treble the dipole pattern is achieved merely by virtue of a pair of highly directional tweeters aimed in opposite directions.
At the other end of the spectrum, I think there must be a point where the wavelength is so great that cancellation between the front and the rear is essentially perfect, such that the effect would not become appreciably worse as the wavelength increases further. The only way I would expect to hear much deep bass from any dipole radiator would be if I were sitting close enough to the speaker that the wavefront coming directly at me, from the two woofers, will be greater in strength than the wavefront that reaches me by propagating around the baffle from the other side. The wavefront that comes from the far side of the baffle has a slightly longer distance to travel, and spreads out more, and is thus slightly weaker than the wavefront that travels a shorter distance to reach me. But when you listen from a distance where the difference between the two distances is minor in relation to the distance, this effect goes away. For any listener a reasonable distance from the speaker and for wavelengths at least a few times greater than the baffle width, it seems likely to me that the wave cancellation would be essentially complete. I would not expect to hear much of anything below 100 Hz unless I were sitting within a few feet of the speaker and directly in front of it, not off to either side. It need not be said that Linkwitz understood this perfectly well. This was the reason that he designed and built the subwoofer, the Thor (if my memory is correct he did the Thor when he was still focused on the Orion, prior to the LX521).
The reason I have just now written all of this is not to disparage the speaker. I was curious about whether people who own the speaker are satisfied with the deep bass, and the answer from one person suggested an absence of understanding of the unique characteristics of the design. So I thought I would take the time to write a few words about it. For what it's worth I'm a great admirer of Linkwitz partly because of his independent spirit. But I suspect that if I owned either the Orion or the LX521, I would also be an owner of either Thor or some other subwoofer that I thought would do justice to the Orion or LX521. In the Orion/Thor crossover he designed, the handoff point was surprisingly low, around 50 Hz or 60 Hz. I would be inclined to do this differently, choosing a subwoofer known to give a flat response to somewhere up around 200 Hz. For this particular application I would be inclined to use shallow, 1st-order slopes, so that the Orion or LX521 gradually yields to the subwoofer starting where the wavelength is already several times greater than the baffle width, because at this wavelength (about 5.5 feet at 200 Hz), the excursion of the drivers will already be much greater than it will be for the same woofers in a conventional enclosure (greater excursion is needed to make up for the front/rear cancellation and is accomplished by way of equalization).
In writing this it was certainly not my intent to step on anyone's toes and I hope that I've not done that. I just got the sense that some of this is not very well understood and I thought that it might be appropriate to sort of rehash some of it. With every unconventional approach to speaker design, there are fundamental questions that cannot be overlooked by anyone who is naturally curious about loudspeakers and acoustics. With the Orion and the LX521, one of these fundamental questions is concerned with dipole speakers generally, and the question is whether, given that the dipole pattern is inherently unachievable in bass frequencies where the wavelength is several times greater than the width of the baffle, it is nevertheless desirable for the radiation pattern in the midrange and treble to be dipole. I don't have an answer to this question. I only know that it is a meaningful question that wouldn't be overlooked by anyone who is fully objective, and that conventional wisdom strongly suggests that any attempt to achieve the dipole pattern in bass, especially deep bass, would very likely yield a compromised result that is neither dipole in radiation pattern nor satisfactory in the more obvious respect.
Congrats!!! How many hours did it end up taking?
Hmmm, dunno. The birch finishing was a constant on-and-off over 10 days because Waterlox requires a solid 18-hour cure between coats. Also, the glue-ups went in stages with 24-hours between things. Let's just say, I was less depressed in this awful time for the 3 weeks I worked on the project, except when we lost power and heat for a week when the temp went to 10-degrees F and my house was 45-degrees F.
Dave.
It is quite obviously you who has stepped into something only for the express purpose of trolling me. This is the second or third time you've done this, maybe the fourth time. It has now become entirely apparent that you are in fact trolling me, and it has reached the point where I feel it is appropriate to ask @BDWoody to take appropriate action. This is not something that I would do except in extraordinary circumstances where it has become entirely apparent that another person is in fact trolling me.
I will ask you to cease making vacuous assumptions about what I have and have not read. It is patently insulting and not the least bit appropriate.
The longer post I wrote on this thread, that I wrote posted just several minutes earlier, before I saw this from you, will hopefully leave you with no genuine doubt as to the fact that what you have done here is the action of a troll, plain and simple.
Thanks for a response from someone who actually owns these speakers. . . . I don't have an answer to this question. I only know that it is a meaningful question that wouldn't be overlooked by anyone who is fully objective, and that conventional wisdom strongly suggests that any attempt to achieve the dipole pattern in bass, especially deep bass, would very likely yield a compromised result that is neither dipole in radiation pattern nor satisfactory in the more obvious respect.
My Orions had adequate bass, for sure, and the LX521.4 do too, but what Siegfried emphasized, and which I find to be true in spades, the sound quality of the bass is different than that from box speakers, and it can be deceiving.
In a concert hall with live instruments, bass doesn't thwack and pump like box subwoofers do; it sort of shoots across you and then is just gone. I think the Linkwitz open-baffle woofers do a better job of recreating that more natural feeling, but it's a lot more fleeting and less conspicuously boomy than boxes. Until I heard the Orions back in ought-seven, I had never heard realistic-sounding bass from a speaker system. The V-frame, open-baffle of the LX521.4 is the same. There's a solid foundation, but it doesn't sound forced or boomy. I think you have to adjust the expectations you've built up about what bass from a speaker system is supposed to sound like, not in quantity terms, but qualitative terms.
