JSmith
The DO100 uses digital "volume" attenuation as far as I'm aware.I am not sure how the volume on the SMSL DO100 works but it does not appear to work in the digital domain
JSmith
If so then why would I hear obvious digital clipping even when the volume is set to 20 out of 99? I hear the exact same clipping at the exact same spots in the sweep whether the volume is set to 10 or 99. If I set the attenuation to -8 dB either in the convolver or in Foobar2000's volume control then the clipping stops.The DO100 uses digital "volume" attenuation as far as I'm aware.
JSmith
Of course it doesn't work. Unless the two subsystems are integrated, you need headroom allowance in each part of the pipeline. Once you clip in the convolver, there is nothing the DAC can do to correct that.After reading this thread I thought rather than use the attenuation in the convolver I would just set the convolver attenuation to 0 dB and turn down the volume on the DAC until the 0 dB sweep did not audibly clip. This did NOT work.
OK that makes sense.... never really thought about "convolver clipping" as something separate from other digital clipping before. So that means there are multiple sources of potential digital clipping. Do you think a 0 dB sweep is a good test of the entire system or is it "too strict"?Of course it doesn't work. Unless the two subsystems are integrated, you need headroom allowance in each part of the pipeline. Once you clip in the convolver, there is nothing the DAC can do to correct that.
It is as energy in music drops off quickly above bass. So I test with music that has strong bass and if that doesn't clip, nothing else will either. You usually see that in my headphone EQ settings.Do you think a 0 dB sweep is a good test of the entire system or is it "too strict"?
Averaged energy yes, but for short transients there is no real frequency dependence.It is as energy in music drops off quickly above bass. So I test with music that has strong bass and if that doesn't clip, nothing else will either. You usually see that in my headphone EQ settings.
It took me some time to think about itUs forcing it will mean all DACs will eventually lose 3 dB of dynamic range or whatever this needs to be.
Us forcing it will mean all DACs will eventually lose 3 dB of dynamic range or whatever this needs to be. So best think about what you are asking.
Non-computer source. And if your DAC has an ASRC upstream of the volume control (cough, cough miniDSP) then what?
Michael
Lots of contradictions overall, if I may:Why? Roon player will output correct values over SPDIF just as well. Or do you mean from a non-computer source? If so, once again, buy a DAC with volume control. That is the correct solution regardless of this issue anyway.
I never saw a realistic ISO example (music, not a test signal) that could not be fixed by lowering the level a few dB. Do you have examples of music recordings having digital peak levels -3 dB or lower that have ISOs?... You - and many here - also fall in the trap of connecting loud music and ISOs; I’m pretty perplex as to why it is so. You get plenty of ISOs with all kinds of loudness. And the ‘funny’ part is that when they clip, they have a higher probability to be heard with softer music! Louder material is less problematic regarding ISO mishandling.
It is basically completely off to bring the loudness discussion on the table.
That's fine, my request remains.You’re talking peak, I’m talking loudness (RMS/LUFS).
I talk peak because it demonstrates that ISOs are intrinsically related to loudness wars. Any music recording that has ISOs will be "fixed" simply by reducing its overall level by a few dB. This is true no matter its loudness/RMS/LUFS. And because ISOs are so easy to avoid, when they happen it must be intentional (assuming most recording & mastering folks are competent professionals).(You keep talking peak, I’m talking loudness.)
Do you know when the first international standard (recommendation, really) for true-peak metering was created?The root cause is recording & mastering folks intentionally abusing the recording format to make recordings as loud as possible.
Of course we will.I talk peak because it demonstrates that ISOs are intrinsically related to loudness wars. Any music recording that has ISOs will be "fixed" simply by reducing its overall level by a few dB. This is true no matter its loudness/RMS/LUFS. And because ISOs are so easy to avoid, when they happen it must be intentional (assuming most recording & mastering folks are competent professionals).
You mention 3 possible solutions - I'll add one more, the "do nothing in the DAC" solution:
The "headroom issue" is not a limitation of the recording format or the DAC. The root cause is recording & mastering folks intentionally abusing the recording format to make recordings as loud as possible. Addressing this in the DAC doesn't address the root cause, but only puts a band-aid over the effects. Doing so would likely be counterproductive, since if we "fix" it in the DAC then those folks will only up the ante and make recordings even louder.
Recommendations aren't obligatory, make it the Law! Make it punishable, and then we'll listen. Maybe.Do you know when the first international standard (recommendation, really) for true-peak metering was created?
2006. That is more than two decades after the commercial introduction of CDs.
Even today, most DAWs on the market only display sampled values and require the user to manually change them to true-peak. Oversampling is also likely to be disabled by default in any DSP processor, to accommodate lower-end computers.
In practice, this means that you can work with too little headroom... and never see a warning, even with conservative production choices.
Take this well known track for example. Does it look/sound smashed to you?
But don't make me say things I didn't say. This is just to illustrate the idea that ISPs are not merely a by-product of compression and limiting. Although, in this particular example, I wouldn't care about only 5 clipped samples out of almost 12 million. See, I'm not that unreasonable after all
Yes, smashing things creates more 'opportunities' for ISP (simply because you spend most of the time close to the maximum), but that is *not* the only reason. And yes, we can rant all we want about engineers not using enough headroom. But it won't change the way music has been created and distributed for decades.
Fortunately, most things have changed for the better: true-peak is now a more familiar concept, oversampling is easier to implement, content normalisation is widespread, and computing resources allow better-sounding implementations.
Sorry to pick on you, but please don't perpetuate and repeat the tired cliché that audio engineers deliberately push things because they just enjoy destroying audio. And remember, they are first and foremost service providers, whose clients are artists and labels. They get the last word because they pay for the service.
Again, ISPs are not a 'problem' per se, but a logical consequence of the sampling theorem, which requires headroom at every stage because the sampled values are always less than the original/reconstructed values. There's no debate about this fact. The question is what to do with this knowledge, especially for music released at a time when this was not an intuitive idea.
I've seen Amir's replies (thanks, by the way), and while I disagree with the SNR argument (@popej expressed my opinion perfectly in post #167), I understand how difficult it is to find the right stance on this topic for ASR reviews as a whole. But what I do know for sure is that it was extremely informative and entertaining to discover @edechamps' reviews, in which he made great use of ISP test signals to better understand the behaviour and overall design choices of the equipment he was testing![]()
I agree - 5 ISOs among 12 million samples (4.5 minute song) is not a practical problem. And the track you showed looks way better that many others that I have seen. If they were all like that, we would not be having this discussion. But even those 5 ISOs will disappear if you lower the overall level by 1-2 dB.... But don't make me say things I didn't say. This is just to illustrate the idea that ISPs are not merely a by-product of compression and limiting. Although, in this particular example, I wouldn't care about only 5 clipped samples out of almost 12 million. See, I'm not that unreasonable after all![]()
Which is another way of saying they are causing the problem by recording too loud. Put differently, there are 2 ways ISOs happen:... Yes, smashing things creates more 'opportunities' for ISP (simply because you spend most of the time close to the maximum), but that is *not* the only reason. And yes, we can rant all we want about engineers not using enough headroom. But it won't change the way music has been created and distributed for decades.
It's not a tired cliche, but a well known fact that audio engineers in certain genres of popular music are deliberately pushing things to sound as loud as possible. Just look at a random sample rock/pop songs produced or remastered in the last 5-10 years and you'll hear it and see it in wave analysis. Plenty of examples posted here at ASR by myself and many others. Just because they do this intentionally, does not imply they enjoy it. Even if they are serving the desires of their studios & artists, who want their song to sound louder than the others people listened to on their streaming service, they are contributing to the vicious cycle of the loudness wars.... Sorry to pick on you, but please don't perpetuate and repeat the tired cliché that audio engineers deliberately push things because they just enjoy destroying audio. And remember, they are first and foremost service providers, whose clients are artists and labels. They get the last word because they pay for the service.
All this discussion aside, I share your curiosity about how different DACs handle this.... I've seen Amir's replies (thanks, by the way), and while I disagree with the SNR argument (@popej expressed my opinion perfectly in post #167), I understand how difficult it is to find the right stance on this topic for ASR reviews as a whole. But what I do know for sure is that it was extremely informative and entertaining to discover @edechamps' reviews, in which he made great use of ISP test signals to better understand the behaviour and overall design choices of the equipment he was testing![]()
