willow
Khadas Tone Board Looking for Reviewers!
Thank you for AudioSciencereview.com allow us to post a thread of Khadas Tone Board here and let more user know our Tone Board.
And we take this chance to invite the forum members to ask for sample reviews.
Please link to http://szwesion.com/free-sample/ to get more free sample reviewing details. if you have any product question, please feel free to reply here and we will answer all your question as soon as possible!
Thank you @
User Manual: Link to Khadas Forum
Khadas Tone Board Unboxing Video on Youtube.
Hi-Res Audio Board Designed for Music Fanatic.
Khadas Tone Board is an amazing USB external Hi-Fi sound card in Khadas family.
Its excellent performance and compatibility will take the listening experience into a whole new level.
And that’s just the beginning…
Inherit Khadas Consistent Breakthrough Design.
We integrated XMOS advanced multi-core RISC architecture microcontroller and ESS flagship 32-Bit stereo mobile audio
DAC ES9038Q2M in such a small PCB. And, we choose 3 independent high performance OPA and
4 ultra-low phase jitter oscillator for best noise reduction. The same as you think,
each power supply path is powered by an independent, ultra-low noise
power supply and the OPA is powered up to ±5.5V.
There are a lot of examples of such designs, but in general,
we try our best to get better performance through optimal design.
Flexible Interfaces Support Secondary Development
Khadas aspires to help the DIY enthusiasts grow by achieving their ideas and dreams step by step, as well as Tone Board.
Khadas Tone Board has 2 RCAs for analog output @ 2.0Vrms
and 1 RCA for S/PDIF in or out.
For Extension:
More good News:
Khadas new heatsink can fit with VIMs and Tone Board.
Convenient for customers to develop and Mold/Enclosure/Case design
So that the customized product can evolve from idea to reality ASAP.
Ultra-low Phase Noise Clock Jitter.
The SiTime ultra performance oscillator SiT820&8209 series with just 0.5ps phase jitter
and output frequency stability as low as ± 10PPM. We chose it as a reference clock
in our audio system so that the data clock jitter < 30ps.
Thank you @
For Extension:
- One 30-Pins FPC Connector for 8 Channels Analog Output Extension
- Two 10-Pins FPC Connectors for OLED Display and I2S Extension
- One 40-Pins Female header is used for connecting VIMs
- One 20-Pins SMT Header for debugging XMOS and VIMs
More good News:
- Khadas Tone + VIMs connected through GPIO Pins
- Generic Edition won't have GPIO Pins on board.
- Tone + VIMs will have GPIO Pins
Key Performance Parameters:
THD+N ≤ 0.000337%
Tone Board has excellent THD+N parameter that means we can
barely hear the distortion over the THD+N signal ratio.
THD+N ≤ 0.000337%
SNR ≥ 120dB
The higher the SNR means the clearer the sound in audio system.
Generally, the SNR need to be lower than 110 dB in Hi-Res audio system.
DNR ≥ 120dB
The DNR which let’s hear a wide range and very subtle sounds,
meanwhile, the sound field is horizontal and vertical,
and the sense of space and layering is like a live concert.
Crosstalk (Channel Separation) ≥ 127dB
The higher the crosstalk separation, the higher the isolation level of the
left and right channel so that you can get stunning stereo effects.
Frequency Response ± 0.08dB
Tone Board can output stable enough signals at each frequency point. For the bass,
the low frequency sound is enough but not boom and no dryness, and the alto,
the person’s Voice of middle frequency is close to the front,
the tooth sound is clear and it has the high definition and
the degree of separation, finally the treble is not sharp
and it’s transparent with depth.
Sample Rate and Compatibility.
The XMOS USB audio to ensure a rock-solid connection. We selected to use the
XMOS XU208 microcontroller for its stability, powerful functionality,
and its reliability. You can be sure that the Tone Board will just
work when connected to most audio sources,
such as computers and mobile media terminals.
