KEF Blade 2 Meta review by Erin's Audio Corner
Status
Not open for further replies.
thewas
Written review isn't online yet, so for now just some screenshots of some important measurements:
Real excellence, one of the best passive loudspeakers currently, hope in many years I will be able to afford a used pair. Interesting also that Erin say they are not only objectively in each category some of the best if not the best measuring but also the best sounding loudspeakers he has heard. Several years ago I had the luck to hear the original Blade 2 in an acoustically good setup and it was also one of the best stereo reproduction experiences I ever had.
Edit: The written review is now online too https://www.erinsaudiocorner.com/loudspeakers/kef_blade2_meta/
mj30250
No surprises there, this is truly a complete SOTA passive speaker package in virtually all ways. If only I could demo a pair in my house versus a Best Buy showroom, even if to simply satisfy my curiosity.
Matias
São Paulo, Brazil
As good as it gets. The Blade 1 Meta extending even a little further down. Excellent review.
thewas
thewas
Not always a good idea, many years ago I had the luck to hear the original Blade 2 in an acoustically good setup and since then I wish I had them. :D
mj30250
I'm fortunate to have landed on a setup that for the first time, after many years and many different speakers, I am fully satisfied with. That was never the case prior. But yes, curiosity can get you into loads of trouble, I agree. :)
thewas
thewas
But the Blade 2 Meta has a bit smoother and more continuous directivity in the lower region (it was the same also on the first generation) and would be personally my choice if I didn't need the extra SPL:
thewas
thewas
Truth to be said I am also satisfied a lot of with my current setups and probably around 80+ % of it subjectively, but when you know how it can be even better, especially the imaging but that was also partially due to the difference in room acoustics, so I would need also another and bigger room which is a much larger problem than getting the Blades...
Ken Tajalli
London UK
Funny!
I heard these at an exhibition, and they sounded pretty crap!
At the time, I was pretty disappointed, as I expected better from Kef.
Why? I wouldn't know.
Reactions: CMB
MacClintock
They should, being bigger and having larger drivers. But strangly, if you go to the homepage, the +- 3dB specs say otherwise. Maybe an error there?
dfuller
Yeah, that's pretty exceptional for a passive. Bloody expensive though - with amps fit to drive these you're looking at probably 35k. That's a hard number to justify when you can get very similar levels of performance out of actives for about a third as much.
Matias
São Paulo, Brazil
Huh, you are right: the Blade 1 Meta does not extend much further than the Blade 2 Meta at all, just a little bass bump and I assume probably even less compression.
FrantzM
In these days of circa $1000 for 500 wpc Class D amplifiers.. Not really. Just add the price for a good preamp (miniDSP?) and you are done
Of course you need to add the price for Synergistic Research speaker cables ...
:p
NOT.
Peace.
Status
