Which ones?I think there are lots of speakers which has similar PIR and cost less. None of them in real life sounds like the blade 2 metas
First gen blades are all good, just a big distortion at 500hz~The Blade 1 sounds so good that I can find no reason to upgrade to the meta's. I see the spins and appreciate how they can help determine in room sound or placement, but When I post direct threads questioning how to measure resolution and the responses I get all say resolution isn't measurable except for a lack of distortion. Just compare the salon 1 to the salon 2 and the biggest difference is soundstage, imaging, and resolution. With soundstage and imaging I get answers that those things are imagined and irrelevant because they confuse accuracy? When we get to the $10k price the things that we don't have measurements for become more important otherwise we'd all own the same 1 of half a dozen offerings.
is quite high vs newer KEFs, in 14~ years kef improved a lot their driversIDK what volumes the distortion becomes a distraction, but I don't hear it and for the investment required to make the change I would definitely need to be distracted by it.
Yes, lower distortion in the newer models. Both old and new need some shelving in the deep bass to be fullrange if freestanding away from walls .is quite high vs newer KEFs, in 14~ years kef improved a lot their drivers
Sorry for the tinny image but as you can see, the distortion from the new models are much better
That cannot be generalised as it depends also on the amount of room gain.Yes, lower distortion in the newer models. Both old and new need some shelving in the deep bass to be fullrange if freestanding away from walls .
I probably saw it and interpreted it all wrong, but I think I saw, quite some time ago that a non Meta Blade can be "updated" after contacting KEF. Do not take this as a certainty because my memories of reading that are foggy.The Blade 1 sounds so good that I can find no reason to upgrade to the meta's. I see the spins and appreciate how they can help determine in room sound or placement, but When I post direct threads questioning how to measure resolution and the responses I get all say resolution isn't measurable except for a lack of distortion. Just compare the salon 1 to the salon 2 and the biggest difference is soundstage, imaging, and resolution. With soundstage and imaging I get answers that those things are imagined and irrelevant because they confuse accuracy? When we get to the $10k price the things that we don't have measurements for become more important otherwise we'd all own the same 1 of half a dozen offerings.
True, the undertuning of the reflex system might even be an advantage with smaller rooms with lots of roomgain.That cannot be generalised as it depends also on the amount of room gain.
Analytical Analysis - Room Gain
-Introduction- The term 'room gain' is often seen used when the topic of subwoofers and the low frequency sound reproduction comes up. As I see many explanations that are lacking or incorrect, I thought I might try and clear up the topic once and for all. In all rooms there are so-called...www.audiosciencereview.com
The crossover points are different, the woofers are improved. Cabin also has a different arrangement of absorbing materials. Theoretically it can be upgraded but it’s going to cost hell lot.The Blade cannot be updated to the blade meta, at least KEF hasn't offered a kit to date.
What would you call "smaller rooms"?smaller rooms.
Money aside, and with appropriate and adequate subs to support good bass support across the listening positions, is there any reason to choose one over the other (Blade Meta 1 vs 2)?
What is the best device to run Dirac ART?new paradigm
Great, thanks very much.Only Storm Audio support it (at this point in time)
Marrantz and Denon are rumoured to support it this April.
I dont know what Kef means with smaller rooms with blade 2 meta ( they say so in the paper , not my words ) .What would you call "smaller rooms"?
I would use a pair of subs to even out the bass across a broader spread of listening areasNo problem using subs below 30 Hz but why should you in such an expensive speaker ?
Euro living rooms are around 20 to 30 square meters. In that space, you can get good SPL with relatively small speakers.I dont know what Kef means with smaller rooms with blade 2 meta ( they say so in the paper , not my words ) .
Maybe they mean european living rooms ?
No problem using subs below 30 Hz but why should you in such an expensive speaker ? its 8 bass drivers 6.5 inch big so there would be no problem making them fullrange in the first place, … except for maybe marketing reasons ( buy the bigger blade 1 or buy Kef subwoofers )
