They won’t have when placed in an actual room, if you feel you need more treble just EQ.
I thought that in an actual room and some distance roll-off should be higher and more declined not lower,at least that's what all in-room response measurements show.They won’t have when placed in an actual room, if you feel you need more treble just EQ.
So we say the same thing,in an actual room slope will be more declining.H/F is always absorbed by furniture and the air itself at least in traditionally furnished rooms,
Then in this case it would be even more sloping than flat on axis speakers.H/F is always absorbed by furniture and the air itself at least in traditionally furnished rooms,
I think we are saying the same thing.
Yes but the degree of target curve is your personal preference.Then in this case it would be even more sloping than flat on axis speakers.
With the greatest respect to Stereoplay, it's worth looking at some other published measurements tooThat’s my feeling. You are free to believe what you want to believe.
So that roll off is not present in real, which is what I wanted to hear. Thanks.With the greatest respect to Stereoplay, it's worth looking at some other published measurements too
I would think that the Klippel measurements, from Amir and Erin are more accurate and not the Stereoplay source you quoted?To be honest, I didn’t feel there was a roll off of 6db. The details were all there but bit muted. But there was some megaphone effect on the Kef which I did not understand what part was making it sound like that. To me, reference 3 sounded Like the highest quality hyper detailed megaphone one can buy, paired with some high quality subs.
I didn’t say I heard a roll off, but I meant the graphs has a 6 db roll off. So stereoplay has to get their ducks in the row than me.I would think that the Klippel measurements, from Amir and Erin are more accurate and not the Stereoplay source you quoted?
Erin R5
Erin Reference 1
Amir R3
KEF R3 Speaker Review
This is a review and detailed measurements of the KEF R3 stand-mount (bookshelf) speaker. It is on kind loan from a member who sent a pair to me at great cost (they come two in a box). The R3 costs US $1,999 for a pair. The R3 is an example of superb industrial design by KEF: It oozes...www.audiosciencereview.com
Nuyes (not „full“ Klippel)
KEF R3 meta Measurements
Hi, I measured the KEF R3 meta loudspeakers this time. These speakers have just been released, but I was able to get a pre-order sample (a pair) from an audiophile in Korea. Impedance Frequency response I measure HF responses using a 5ms window gating. Therefore, the...www.audiosciencereview.com
No 6dB roll off.
I think you should get your ducks in a row (facts right) first before making a claim, that something is flawed.
And let’s separate facts from personal preference.
Its a slight something in the upper treble which was making it bit sharp. I listened to another speaker which has a poorer directivity in the same room but with more extended bass and treble response. It sounded more relaxing despite a directivity error in the 2-4khz region in the very same room.Brightness that causes listener fatigue isn't in the high treble. It's in the 2-5 kHz range, typically close to the crossover point. High treble behavior defines extension, not brightness.
This is, of course, my opinion...
You didn't as far as I got it right, not clearly state which speaker type you auditioned under what circumstances. I reads more like theoretical musings originating in a short term experience at some random location?Its ideal to have a flat on axis response and a slopping off axis response of the same pattern. KEF‘s on axis is slopping, compared to other speakers. Yet when I tried listening to Reference (non meta version) it sounded very harsh, bright, despite the 6 db sinking in treble region. Now I am trying to undertand if Kef guys knew their tweeters are somehow too sharp and wanted people not to hear it, so they rolled off the on axis. Still some people call it neutral. that’s no way neutral with that roll off, normally we wont put a cloth over cymbals before we listen to them!. Is there a reason other than this to have a rolled off on axis response?
Ok, so now in thread title, put a strike line through "KEF" and insert "Stereoplay"So stereoplay has to get their ducks in the row than me.
EQs existed since 70s or even before. The crowd who never digested the idea of the EQ would never like the idea no matter what.Not to put too fine a point on it, but it's 2023. If I had to live with a commercial offering, I'd definitely EQ it how I pleased. The chances of them getting it just the way you like are very slim.
True, although they were bulky back then and generally "featured" fixed Q. These days you can EQ without doing more damage than you fix.EQs existed since 70s or even before. The crowd who never digested the idea of the EQ would never like the idea no matter what.
