ThatSoundsGood
- Joined
- Aug 12, 2022
- Messages
- 409
- Likes
- 408
With really good mastering engineers, the limiter often doesn't cut the transients (or cuts them very slightly or rarely). They are turned down but the integrity of the transients is maintained. This again is why I have an issue with calling it clipping. The term "clipping" is generally used in Pro Audio to signify that the signal has gone past the headroom of the circuit, especially when a digital circuit is clipped. A good combination of compressing and limiting will keep the integrity of the transient more often than not. This is what the mastering engineers have gotten so good at. They can squash the master but maintain the transients and the dynamic perception of the music. There are so many ways that they accomplish this.Technically, it's done the other way around than how you describe it.
Digital clipping is something I'm sure all mastering engineers avoid. What is technically happening is that the limiter "cuts" the transient peaks and creates a larger headroom, and that larger headroom makes it possible to increase the overall level of the music track. Most mastering engineers increase the level until the highest peaks reach -0.1 to -0.3 under digital clipping.
I don't see anything wrong with you calling the limiting "clipping", as it is a form of controlled clipping which can be made to sound "softer" than the digital clipping that would otherwise occur if the transient peaks were hitting digital zero.![]()
One interesting thing is that there was a time when many of them were using some Burl A/D converters and they would clip the input of the circuit and it sounded amazing. This was actual clipping of an analog circuit (which sounds a lot better than clipping anything digital).
Another interesting note is that recording to tape actually makes transients more round because tape has natural compression. This whole topic is so much more complicated than what the cult of hifi understands.
Edit-----Another way to describe the end result of mastering and what you're seeing in the waveform is this:
The transient is still there but everything else is turned up louder after it. So the result is that there is less magnitude between the transient and everything else so the waveform looks different. But since the master waveform is a combination of many instruments projecting different frequencies, it looks square because everything is being turned up to the same level as the transient. But the transients are usually still there. It's just the other information is now louder.
