I checked out the "Bassy" Castor for 19 bucks. I am not even so much into Harman but I also wanted the silicon eartips for my D-Fi, and I also thought if I dont like them I can send them to a friend who is a "basshead". Mainly just out of nerdy curiosity to be honest.
The ear tips contained a little fail: I got 2 small ear tips, 3 mid-sized ear tips and 1 big ear tip.
But the mid-sizes ones are okay.
Even though KZ themselves say otherwise, the "bassy" black one seems closer to the Harman curve than the white one, as long as you switch to a lower bass level (havent checked them out yet though). For example, the UUUU tuning does not sound overly bassy to me. It is similar to how I imagine the praised Truthear Zero to sound like. You can turn the bass even a bit further if you want to, but that does harm the tonal balance (it gets too bright).
The shell of the Castor has the same fit as the shell of the D-Fi but is slightly different, as it is transparent from the inside. It is slightly lighter and feels slightly cheaper (well, it is).
Compare hundreds of frequency response graphs between IEMs and earphones from manufacturers like Moondrop, Sony, 64 Audio, Fiio, and more.
practiphile.squig.link
