Interesting, but what changes have you noticed? And from where did you get this mesh?I've been pretty much maining my Castor standard since getting it. To make it a tiny bit more crankable I added 200 mesh to the nozzles. It's the lightest grade mesh.
I got the mesh from here: https://www.aliexpress.com/item/1005004092269560.html Some use foam as an alternative, the mesh is a little more convenient with it's standardized values 200-500.Interesting, but what changes have you noticed? And from where did you get this mesh?
Today I found another video that corroborates its magnitude response, but I have no idea of what it tells.
I keep looking for more complete measurements (THD, impedance, real IR, multi-tone, etc) but I can't find anything anywhere.
Preamp: -1.6 dB
Filter 1: ON LS Fc 110 Hz Gain 1.0 dB
Filter 2: ON PK Fc 38 Hz Gain 0.7 dB Q 1.5
Filter 3: ON PK Fc 170 Hz Gain -0.5 dB Q 0.7
Filter 4: ON PK Fc 550 Hz Gain 1.7 dB Q 1
Filter 5: ON PK Fc 1200 Hz Gain -1.4 dB Q 2
Filter 6: ON PK Fc 2150 Hz Gain 0.6 dB Q 2
Filter 1: ON LSC Fc 175 Hz Gain -0.5 dB Q 0.47
Filter 2: ON HSC Fc 16000 Hz Gain -1.5 dB Q 0.33
I got both for $22.00 they are an incredible value.I got the Castor Harman and Castor Bass for £17.86 total.
How is this not the budget king?
I have seen the KZ Castor (Harman/Silver/Std) as low as 7€ a few days ago. It cost me around 15€, and I wouldn't have bought it otherwise, since KZ has earned a bad reputation for itself. For this model KZ doesn't even specify its THD, just figure the reason...I got both for $22.00 they are an incredible value.
Also I ordered the CCA Polaris for $11.00 just to check it out.
Maybe because KZ is not reliable, and around 20€ you have better alternatives.I got the Castor Harman and Castor Bass for £17.86 total.
In a way the bad reputation is to be expected, their offerings are way cheaper than the competence (there is a lot of drama in the IEM industry). Personally all KZ products I have received have not suffered from bad quality control issues not any other brand for that matter, I have been lucky.I have seen the KZ Castor (Harman/Silver/Std) as low as 7€ a few days ago. It cost me around 15€, and I wouldn't have bought it otherwise, since KZ has earned a bad reputation for itself. For this model KZ doesn't even specify its THD, just figure the reason...
By the way, it took a long time to arrive, and I'm still waiting for the mesh.
Don't worry too much about the mesh. It's mostly useful if you want to listen with a lower than average bass level, and need to balance out the upper mids for it. Lately I've enjoyed more bass and removed the added mesh on mine.I have seen the KZ Castor (Harman/Silver/Std) as low as 7€ a few days ago. It cost me around 15€, and I wouldn't have bought it otherwise, since KZ has earned a bad reputation for itself. For this model KZ doesn't even specify its THD, just figure the reason...
Edit: A budget king, maybe, if they charged 7-10 € for it...
For a long time I thought that the pinna gain of the Harman curve was too bright to me but after a long time experimenting with various curves, combination of curves and IEMs I just find out that a gradually reduced treble (+/- -2.5dB) from around 3kHz and on plus a 1dB or so of bass/mid-bass sound more open, balanced and natural to me.
Thank you very much for the comment, the truth is that I have been trying them (without mesh) and I like them quite a lot, but with high volume I notice something weird, I would like to see a multi-tone test at 90 or 94 dBSPL.Don't worry too much about the mesh. It's mostly useful if you want to listen with a lower than average bass level, and need to balance out the upper mids for it. Lately I've enjoyed more bass and removed the added mesh on mine.
Something a bit harsh in the treble?but with high volume I notice something weird
It makes sense, the same happened with the Zero Blue too much unit to unit variation.It makes sense, you're just like tweaking the tilt, take a look at the following graph (all Truthear xCrinacle Zero:Red with narrow tips) :
It is difficult to see, but there are two groups very peculiar (in this regard ):
Perhaps you are just adjusting its "misalignment" with respect to Harman, without a measurement it is difficult to know.
D-Fi was unimpressive to me. Castor Standard is the only KZ worth getting probably.I got Castor Harman (silver one), Krila and D-Fi (no tuning version) on sale, especially Castor was dirt cheap. To my ears Castor (DDDD) >= Krila > D-Fi as tonality and seriously D-Fi is the worst in the bunch. Castor is fine as it is and the price is incredible. On the other hand, although D-Fi is fine with EQ I don't recommend it at all, since there are many many good options for the price range. They all share similar outer shell design, so fit comfort is almost the same.
By the way, normally I use middle tips for my IEMs, but interestingly the colored tips come with D-Fi didn't fit into my ears. I swapped them with L ones and viola! Perfect fit! Those colored tips are actually pretty good and if I can buy them in bulk I might consider chaging the tips of all the IEM's I have.
Finally, I'm totaly done with KZ.
No, it's more in the mid / upper mid range, I guess it's distortion.Something a bit harsh in the treble?
