If one is at FW 2.2, and has little interest in EQ - do you still recommend the update? Thx!
That looks loads better! I reckon it could be used quite effectively as a tone control "across the whole frequency range" whereas before it was mainly bass boost and high treble influence, but now you've got influence across the whole spectrum by choosing 170Hz and 3kHz as a combination to be used together to tilt the frequency response up or down. That's a good change I think!Firmware v2.5.1 is now available, following successfully testing since late last week. Changes include:
- DSP Performance Updates
- Optimized DSP stages to achieve static-free PCM 352.8kHz and 384kHz support
- Adjusted DoP detection state machine within DSP stages to improve performance
- Corrected volume compensation for negative DSP gains (was set 2dB below nominal in v2.5.0)
- Changed Treble DSP Frequency options to: [3k, 4k, 6k, 8k, 9k, 10k, 12k, 14k]
Revised treble frequency response limits are shown below (note only a few gains are plotted between +/-12 dB):
(Amir actually but in another Low Shelf at 40Hz too, so he had around 6dB overall boost to some parts of the bass. Whenever I've done EQ for HD600 I like it with just +3dB Low Shelf at 75Hz (Q0.707), no other changes.)@remlemasiv - Keep in mind everyone's perspective is unique. I find +12dB @ 100Hz enjoyable with HD-650s. Others may prefer less. For instance, Amir applied 3dB @ 75Hz in this review. There is no right answer.
Yeah, I noticed that too, but if we’re getting technical, I think it’s 8dB overall boost down low. (3dB@75Hz+ 5dB@40Hz).(Amir actually but in another Low Shelf at 40Hz too, so he had around 6dB overall boost to some parts of the bass. Whenever I've done EQ for HD600 I like it with just +3dB Low Shelf at 75Hz (Q0.707), no other changes.)
Fair enough. Although I really appreciate the jdslabs approach to EQ, where it’s implemented as subtractive adjustments only, introducing no additional risk of clipping. This is great when one does want to experiment with absurdly high boostsThese messages all make sense, and I am not objecting - other than to note that, if you must EQ a device by 8dB, you probably made the wrong choice for your listening preferences, IMHO.
Just for a follow up, +12dB@100Hz sounds kinda nuts to me (no offense @jseaber lol). Even +8dB@80Hz is a bit much.
Ended up finding @oratory1990 6-band PEQ settings (harman target) and applying just the low shelf and high shelf: +8dB@60Hz and +3dB@3kHz. Glad the Q-factors match up.
Might be a little bright/fatiguing for me, but will see if I end up getting used to it or if prefer the OG veil
See spec: https://www.dropbox.com/s/p3hcne1z7n965sx/Sennheiser HD650 (6 Band EQ).pdf?dl=0
This isn't meant to be an HD650 evaluation, but more to say I am enjoying messing with these tone controls.
Like I mentioned above, I recently escaped from the the "any/all EQ is blasphemy" mindset and allowed myself the freedom to explore the wonders of modern DSP. I also have much less time now to be super critical and just want to listen to music that "sounds good." (Unfortunately, my gear now easily exposes poorly-mixed/recorded music so it's become harder and harder to do... lol)Just because you *can* do something, doesn't mean you *should*.The feature envelope is designed to let people go crazy - why build a feature with limits that just reflect the designer's preference? It limits its appeal. Let customers do crazy things - it widens your customer base.
I want to set a specific DSP band for the RCA output, to deal with recessed male vocals. I was wondering if there was a way to go about achieving this with the Element III.
I vaguely recall that you are accommodating custom FW with custom DSP filters. Did I mis-remember?This could potentially be accomplished by changing one of the biquad filters to serve as a notch filter (i.e., repurpose the core currently assigned to treble boost). If there are enough requests, it's something we could explore.
Got it, thanks for clarifying.Yes, to clarify, we can quickly compile custom builds which alter predefined variables such as Q or available cutoff frequencies (8 options per filter).
Changing the filter type is more involved, but possible.
