JDS Labs Element IV DAC & HP Amp with EQ Review
Rate this DAC & HP Amp
    Votes: 3 1.1%
    Votes: 15 5.6%
    Votes: 70 26.3%
    Votes: 178 66.9%
This is a review, listening tests and detailed measurements of the JDS Labs Element IV (4) stereo DAC and headphone amplifier with support for parametric equalization. It was sent to me by the company and costs US $499.
The Element IV implements their large and joyful horizontal volume control. It also has a small OLED display that shows inputs, sample rate, volume, etc. It auto shuts off after you make adjustments.
It implements one of my favorite features in headphone amplifiers: auto gain setting. Below 0.0 dB, it runs in low gain mode. Turn up the volume beyond that and it will switch to high gain. The switching is not transparent but not glitchy either. Adjustment of the volume control likewise is accompanied with faint ticks. Again, not annoying.
As with their other designs, it is powered by an AC transformer:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo back panel power supply usb-c Toslink...jpg
It does NOT work with usb-c alone (I tried). On off and RCA/Headphone switches are in the back as you see. A little less convenient to use than front controls. Note that only optical Toslink is provided which it calls S/PDIF. That is technically correct but I kept cycling through the input selection looking for Toslink. Speaking of that, pressing the volume control selects inputs.
The main differentiator here beyond the volume control is implementation of Parametric EQ. For people who don't have access to the same in software/player, this is a critical feature. It did not have time to test it. Company did and reassuringly showed that it has no impact on performance.
JDS Element IV DAC Measurements
I set the volume to max and measured RCA output. With my Analyzer in "floating" input, there was fair amount of USB induced noise. Through grounding the analyzer, I got 90% of that out. I had this issue before with other JDS products so company sent its USB isolator which it calls Synapse. Inserting that in the USB path eliminated all noise resulting in same measurements as company has published:
Distortion is vanishingly small at -130 dB, with SINAD then being noise dominated. Performance is good enough to land in our "very competent" ranking of all DACs tested:
Here is the same zoomed:
Noise performance is excellent, but shy of state of the art:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo DNR Measurement.png
This shows up in IMD test:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo IMD Measurement.png
Linearity is excellent as well:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo Linearity Measurement.png
Multitone is state of the art:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo Multitone Measurement.png
As is 50 Hz into 600 ohm load:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo 50 Hz 600 ohm Measurement.png
There is some random noise/jitter though:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo Jitter Measurement.png
Filter response is the typical we expect with excellent attenuation above 24 kHz:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo Filter Measurement.png
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo Frequency Response Measurement.png
Wideband response is excellent and again, just shy of state of the art:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo THD vs Frequency Measurement.png
JDS Element 4 Headphone Amplifier Measurements
I made a pair of measurements: one with volume at 0 dB and hence low gain, and another at max volume and hence, high gain:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo 300 ohm power Measurement.png
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo 33 ohm power Measurement.png
That is a ton of power, especially into 33 ohm. Distortion is extremely low and no clipping at either impedance. So if you are hearing distortion, it is in the headphone, and not the amplifier.
You do get clipping as you push the amp even more, below 32 ohm:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo impedance vs distortion vs power Meas...png
There is still plenty of power available. As noted, output impedance is essentially zero so no concern there.
Volume control is implemented actively so channel balance stays perfect at all settings:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo channel balance Measurement.png
Finally, noise performance at 50 mv is very good:
JDS Labs Element IV 4 DAC and Headphone Amplifier Stereo 50 mv DNR Measurement.png
Ranking well above average:
JDS Element IV Listening Tests:
My Sennheiser HD650 is out on loan so I tested with the Dan Clark E3 which is low impedance and rather insensitive. The Element IV drove it harder than I had ever heard. I did not even dare to use the last few dBs of the volume control as the impressive bass was starting to resonate things in my ear canal that should never resonate! :D The fidelity was incredible with track after track. You should have no trouble driving just about any headphone with Element IV with superb sound quality.
JDS delivers "A-" performance when it comes to DAC's objective performance. But then goes to A+ on the headphone amp which is incredibly powerful. It gives you delightful control in the form of that large rotary volume control. And of course, equalization. The entire package is incredibly appealing and quite unique.
I am happy to recommend the JDS Labs Element IV (4) DAC and headphone amplifier.
I was recently surfing desktop motherboards and found that USB-C is still not available in multiples of connectors at the motherboard IO plate. I understand multiple USB-C devices may operate from one connector. Are we to use a USB-C hub for multiple devices? What is the method here?
Sure, you use a USB-C hub. That is what I use on my desktop. It has a lot of USb ports but I ran out.
The main differentiator here beyond the volume control is implementation of Parametric EQ. For people who don't have access to the same in software/player, this is a critical feature. I did not have time to test it.
The only feature on this particular unit that I would find interesting and useful and that would set it apart, and no information on it.
What you want to know about it?
Thanks for the review @amirm, I feel this comparison needs an update, we've been seeing stuff compared to Khadas for a good number of years now :D
Yeh, I have been bothered by the same for quite a while. Thinking about updating a bunch of them.
So to get the measured performance requires another $69
Yes I was wondering about this as well. I wonder how it would fare without the isolator? Would the issues be audible or just measurable? I expect it would not be audible.
