respice finem
- Joined
- Feb 1, 2021
- Messages
- 1,867
- Likes
- 3,779
It will probably suffice for a rough distortion assessment, to feed the woofer - and I assume 90+ % of it will be from the woofer and the cabinet, as is usually the case. No solid state amp can "compete" with speakers in this dept. - except it's broken. I had the model and specs of the chip they use, maybe i can find it, but "on paper" specs were decent AFAIR.This may open a can of worms (or judged as a really dumb idea) but has anyone hacked a pair of 308’s by bypassing the internal amps and driving these from a quality, external amp?
Based on Amir’s review, the weakness of their bass performance at volume and he felt that a bit of additional horsepower would really make these speakers sing.
Granted, I’m guessing this hack would require a crossover to be installed to but it seems like the 308s start with, “good bones” and the hiss and lack of punch at volume mignt be solved by this hack.
Considering their reasonable price point, it seems like this isn’t a huge risk.
I did a quick check over at diyaudio and a google search and didn’t find any 308 hacks to do this.
(I’d try this myself but it is a bit above my pay grade so I’m only throwing the idea out. I’ll now don my Nomex suit for the flamethrowers that may soon be coming my way!)
It can end like some cases of car tuning - with having a broken, yet expensive piece of youknowwhat
If lower THD was so simple and cheap to achieve, JBL would have done it themselves.
Lack of punch at volume? Can't confirm, they get (subjectively) as loud as the Neumann do, just not equally clean.
Close to the wall, probably even louder (BR vs. closed box)
