Is there an EQ of Anechoic chamber for JBL305 mk ii?
dingdong3
Hello. I bought 305p of JBL used. I'm very satisfied.
Kali's Lp6 v2 used at work was able to find EQ. But it's hard to find if I'm not good at searching for the EQ for 305p.
Does anyone know the EQ value that ASR member tested and calibrated in Anechoic chamber?
Thanks.
1. Pierre's site has auto-generated PEQs based on raw data from Amir and Erin (from erinsaudiocorner.com). Where Pierre can't get the raw data that's usually from 3rd parties, he'll digitize the CEA-2034 spinorama data, and then run his algorithm against that... it's less accurate than raw data, but it's next best thing.
2. @Maiky76 has auto-generated PEQ based on raw data from Amir.
Since Erin doesnt post his raw data publically, so Maiky can't generate PEQs based on Erin's work.
Click on his profile to hunt down a particular speaker.
He'll post his PEQs inside an individual speaker thread, so you'll have to find it. It's an easter egg hunt.
3. Amir also provides PEQ profiles for *most* of his speakers. Usually in post #1 of his threads.
1. Pierre's site has auto-generated PEQs based on raw data from Amir, Erin. Where Pierre can't get the raw data that's usually from 3rd parties, he'll digitize the CEA-2034 spinorama data, and then run his algorithm against that... it's less accurate than raw data, but it's next best thing.
That's so kind. Thank you!
