Hi all. I ended up buying the ER4SR and received it 5 days ago.
I did a level matching (added -2.7db of pre-gain when using the ER2SE) and compared them.
Subjectively, I felt that there was a slight difference.
I think the ER4SR is more suitable for listening to details. I was able to discover sounds that I had never noticed before.
However, when listening to female vocals, the ER2SE sounds a bit more pleasant to me.
I will keep both, but I still find ER2SE to be an amazing value.
I've had both before BA drivers just sound much better for overall detail & bass speed(diaphragm resting). Which can make DD headphones sound dirty & coloured when you switch back to them. I've seen quite a few on the ER4 thread at Head Fi got shocked the Ety has the detail power as many planar/electrostatic HP's.
Both headphones have a THD below 1%, which means that this distortion is inaudible.
Actually with higher end coupler mics the ER4SR rates <0.3% since a few doing tests with both at Head Fi noticed high 2nd order THD at 94db. Mean much of the published THD tests were from mics clipping not the ER4/ER2.
