Is it "dangerous" to pair an Aiyima a3001 with an AIYIMA 48V10A?
Hevy G
I regret having never taken Electricity and Magnetism: several of the terms are beyond my grasp, as well as how they are interrelated. I am considering buying an a3000 to power a bass shaker (or two), and I am curious to know if this power supply will harmlessly boost (or destroy) the a3000?
Thank you, G
Quote from Aiyima A3001 technical specification: "DC power supply must not exceed 35V" (for 4 ohm load).
You didn't ask, but amperage depends on the load (the amplifier).* It's OK to use a power supply with a higher current rating.
But if the power supply is under-rated and can't supply the necessary current, the power supply voltage will drop and unpredictable "bad things" can happen... The power supply might go into protection mode and temporarily shut-down, a fuse inside the power supply might blow, or the power supply might burn-up and die.
The amplifier will "draw" maximum current when it's putting-out maximum wattage into the speakers.
...There is always voltage present at the power outlets in your home. With nothing plugged-in (or nothing turned on) no current flows. A hair dryer draws more current than a 100W light bulb but the voltage remains (about) the same. If you plug a hair dryer and a toaster into the same circuit, you'll draw excess current and blow the circuit breaker. (If a light dims when you turn-on the hair dryer, the voltage is dropping a bit.)
* Current is also proportional to voltage with a constant load. If you double the voltage into a speaker you also double the current, and that means 4 times with wattage. But with an active-variable load like an amplifier it's not as simple.
@Hevy G my full review will be up soon, but in the meantime yes, 10A is fine, the TPA3255 chip can deliver it and so can the board. You'll be limited to about 230W into 4 ohms and 150W into 2 ohms probably - for some reason this amp doesn't get everything it could out of the TPA3255 in PBTL mode. More importantly in my opinion, it's a bit marginal to run at 48V because the power supply capacitors are only 50V rated. You'd normally expect even a budget design to have 10% or 20% of margin in capacitor ratings because the risk of failure goes up a lot close to the max rating. A 36V supply would have a much lower failure risk.
