danadam
- Joined
- Jan 20, 2017
- Messages
- 994
- Likes
- 1,545
Personally I've never seen anything with actual bitrate higher than 140 +/- a few.Yes, that's correct. Youtube converts to the maximum of Opus 160 kbps.
I like it, thanks!Is this a good recording? Not many likes or even views in 2 years.
Its hard to record a piano in a good way . You need to get the critical distance correct with the distance from mic to the piano and the room - and you need very good microphones.Adding on, when reading the comments, not one person says anything about bad recordings! Are folks this tolerant of distortion and bad sound quality?
Thank you.@John Atkinson has done some really good piano recordings.
Track 10 (Chopin Scherzo in D minor played by Anna Maria Stanczyk) of your first Test CD is not only a very good recording of a great performance, but my go-to test for good stereo imaging. If the "Well done!" exclamation at the end of the track doesn't seem to emanate from significantly beyond the left speaker position, I know something isn't right about the system, its positioning, or the room. It's the most binary imaging test I've encountered.Thank you.
On the general subject of piano recordings, I have always had a piano technician/tuner on call, to make sure the piano is in optimal condition before each session.
John Atkinson
Technical Editor, Stereophile
I have this recording and was going to mention it as an example - but you beat me to it!This recording was done on an essentially broken piano. The full story in the liner notes is as interesting as hilarious.
To me it adds to the impression that I’m listening to an actual event involving an actual musician, which is something I often forget with perfect recordings of perfect performances.
The young lady in the first row doesn't seem to like it. Or that could just be the "my parents made me come here and listen to this" grumpiness.I like it, thanks!
I think a good (or great) piano recording is less about the exact tone of the piano and its recording, or whether it has too little or too much room, but whether it conveys the performance. If recording engineers might argue about how they would have done it differently, that shouldn't matter if it's enjoyed.Is this a good recording? Not many likes or even views in 2 years.
That would be an SOP for any recording session with piano, they need touch-ups regularly during the process.On the general subject of piano recordings, I have always had a piano technician/tuner on call, to make sure the piano is in optimal condition before each session.
It isn't just about piano recordings, but any music recording that captures live playing by the artist, I'd think.I think a good (or great) piano recording is less about the exact tone of the piano and its recording, or whether it has too little or too much room, but whether it conveys the performance.
He is not exceedingly interesting pianist to my tastes, but I do like his solid performances when I get to hear/record them now and then. Will check that recording, thanks for posting the link!One of the best piano recordings in my collection happens to be another Abduraimov performance.
It seems to be rather good advices. The distance from mic to piano strings must be set according to the mic used and the amount of reverb in the concert hall. It may be somewhere between 50cm - 1.5 meter ( 50 cm if its a very reverberant room ) with two good omni microphones. I use 53 cm space between my omni microphones , and this is optimal for listening through 2 stereo loudspeakers after the recording is done.This article is part of the DPA link I posted:
Piano Microphones - How to mic and record a grand piano
Guidelines for miking the grand piano with DPA Microphones.www.dpamicrophones.com
Let me retract the above because Michael Murray - J.S. Bach: Prelude and Fugue in G Major, BWV 541 has 160 kbps:Personally I've never seen anything with actual bitrate higher than 140 +/- a few.
Average bitrate: 160.5 kb/s, w/o overhead: 159.4 kb/s
Good pick! I recently bought an LP of Carla Bley for the honour, although I can also stream her tracks. I like her and the band.If I may recommend a couple of "easy listening" recordings:
Carla Bley ...
