- Thread Starter
- #21
I overlooked that. If you want to connect your PC you will need either the AS801 with its usb input, a computer/card with an optical output, or a cheap external USB DAC.
What use would you make of your computer as a source? I would prefer a Chromecast Audio as a streaming source, but it obviously depends on the use case.
Cables are not an issue. Just use very cheap cable - the rest is snake oil: 1 UK pound a metre is more than enough budget. For longer cables, use somewhat thicker gauge.
I'm pretty set in my ways with foobar and have a large library of FLACs. This is also how I watch all my TV shows and Films. I'm assuming Chromecast is for use with streaming services like Tidal, Spotify and so on? If so I don't use any of those services. I know I should probably get with the times.
Yes, you’re right, I only suggested that route in the case you didn’t want to spend on an usb dac or the module for the soundcard you mentioned earlier.
Might still have to for the time being. Not sure yet.
Appreciate all the help, advice and patience you've shown. Thank you.
