I have bought it and will review "soon."I would like to add the SMSL AD18 into the mix. Being an fully digital 80W amplifier, that retails for €129.
I wonder if someone could recommend me a mini-dac-amp that I can use with my 2017 iMac which no longer has optical output, mainly I need one that uses USB. The speakers are a pair of Klipsch RP-160M (100W@8o) and soon a powered subwoofer. At this moment I use an old 5.1 home theatre LG 805HT with a startexh usb dongle that does 16bit-96khz (LG chokes on 24bit). Also LG has only powered subwoofer output and I am afraid it may not have many more years to live, prefering to sell it for about £50 before it becomes scrap.
The room is quite small (12sqm) and I do listen at low volume so a mini amp should do just fine, still i want something that would be of decent quality and not ruin my buget. Any recomandations? Even what I should avoid would be useful. So far I found the SMSL q5 pro that looks of decent price and with right feature but not sure how it would compare with what I have now.... anuthing else to consider?
Will do.Maybe you could also confirm this when you do review the AD18 (that is if you got version 2 and above).
The Topping PA3 *seems* to have no trouble driving the 4-ohm Elac Uni-fi UB5's. I don't believe they sounded quite as good as they do connected to my more powerful AVR (better placement there, too), but they played reasonably well even at respectable volume. I didn't really push them too hard - it was more of a proof-of-concept for me. Neat little amp! Currently have it driving a pair of Elac Debut 6.2's, and I am pretty satisfied.
This makes sense. Given the same abilities in frequency response, having two bass drivers over one tends to even out some room mode related unevenness.Somewhat oddly, with the original B6's I would flip flop between running the sub woofer and keeping it off, and since moving to the B6.2's, I much prefer listening without the sub. The bass is plenty deep and much cleaner to my ear than running them with the old klipsch 10" sub.
Sounds like low damping factor.Recently I swapped in the PA3 to compare the sound with that of the Pioneer AVR, and the difference was stark and disappointing. Not only does the bass seem over emphasized through the PA3, but the lovely highs that I've been really enjoying out of the B6.2's simply don't make it through in the same way.
Probably room modes. They may have become more noticeable with speakers that go deeper. Measurements could confirm this.The one small mark against the B6.2's that I've noticed is that during some music, certain low frequencies (I assume the ones targeted by the port tuning) do jump out a bit more than those above and below in a slightly unnatural way.
.........When I first received the PA3, I hooked it up in the garage to my BS22s and tried to do a side by side with the SMSL SA-98e amp that I've used out there for the last couple of years. The Topping sounded a bit less dynamic and alive than the SA-98e. I went back and forth trying to match the gain and listen carefully. The difference was somewhat subtle on the BS22's, but it was there. The SA-98e simply sounded a bit clearer and more pleasant....Jeremy
I'm a "convert" to class D and FDA amps. My opinion has little weight, as I 've never owned hi end amps. But my little $70 FxAudio amp runs circle around the two amps I've had in recent years, a ~$450 class AB Teac and a Harman Kardon home cinema
I've revised my judgment in a later post though. I started perceiving some problems with it and no longer think the Fx-audio "runs circles around" the Teac. But I'm convinced a truly excellent cheap class D amp will come out sooner or later. 100% agree with your points.I have one has well. And I do also have hi end amps and speakers (too many ).
While I am a big fan of objective measurements, I still believe opinions matter, at least at a personal level. After all, you are the one listening to your music.
Measurements are essential
- to clear up the FUD and hype surrounding many current "high-end" products, especially everything that involves the digital aspects, cables, etc...
- to identify poor or simply dangerous designs.
- to educate the public.
Listening is essential
- for your enjoyment.
One does not exclude the other, one does not need to fall into the opposing extremes.
I can switch at will between 3 high ends amplifiers and 3 high end set of speakers. Guess what... they sound different. Speakers very much so. Amps much less.
How does the FX 802D fit into that picture? Well, I also have my "cheapest of cheapest" system which consists of a couple to Tannoy passive monitors (I think Tannoy 3 Monitors), a CCA and the FX 802D which I happen to be listening to right now. It is a very nice sounding system for less than EUR 300 in total.
I enjoy it. That is what matters.
I also tried the FX 802D on my Giya G3, Blade II, Kef LS 50, Klipsch reference and yes Bose 901 Type VI it behaved quite decently.
OTOH, I expect it breaks down utterly in terms of distortion at high power. Measurements will tell us that. Will that spoil my enjoyment? I don't think so. SNR at 75dB, 90dB, 100dB? The same.
Allo is sending one of their amps to me for review.https://www.allo.com/sparky/volt-plus-d-amp.html
This one is the sweetheart of these types of devices right now. Would love to see measurements on it.
Topping PA3 owner here.
I wan to join the discussion because i found something that has been bugging me for quite a lot: floor noise.
My topping has a fairly high white noise that happen when no source is playing, clearly udible from 1 meter. the problem is definitely on the amplifer since i tried everything possible.
anyone has encountered the same problem? i already contacted Audiophonics.fr for RMA but i hope it's just a faulty unit since the amp is quite good and i'm struggling to find a proper replacement
the gain on the PA3 is 29,3db gain but it does not say a thing about changing it so i suppose you have to modify the board, but since i opened a support ticket i'd rather avoid open my amp to prevent every sort of controversy with the shop.
Last thing i want to try is to search for some ground issues but i don't have a multimeter so i have to test it aproximately. if this is the problem i will ask for RMA and hope to receive a coupon so i can try something different like the allo volt+d
