How can this:
And this:
Both come from amplifiers with:
PA3s: -87 & -85 dB THD+n
3700H: -89 & -87 dB THD+n
Edit: literally every PA3s line is above -70 and all but maybe 1% of the 3700H's are below -70!
I have the Denon X3700h, and for sure the charts above are a much better representation of the audible performance difference than the 2dB THD+n rounding error.
The chart above.. the PA3s is -65dB THD+n @5W and 1kHz.
Am I missing something? Or is the PA3s supposed to be rated 20dB worse than it is?
Mini review below from the 6 minutes of listening I did before deciding I'll be returning
(2 mins ea of 3 songs I'm very familiar with):
Compared to what's available at big box stores, the PA3s is good value for money, but considered as its own component, it's far from my favourite. The upper treble is too present and slightly harsh. Exacerbated by weak bass which is not only anemic, but lacks definition..
Sure, it probably sounds better than anything you can buy in a "real" store for the same money, but the bar there is pretty low...
If you live in a building and don't need a lot of power, and your speakers are lower to mid entry level with the following characteristics:
- a bit bass heavy
- a soft top end
(which are common in the category)
and your budget is $170 CDN max, I'd say go for it. Otherwise, keep looking!
(I don't know all that's out there - this could be all there is, so before following my advice to keep looking, make sure there's actually other contenders lol) don't forget the used market!
And this:
- a bit bass heavy
- a soft top end
