- Joined
- Feb 23, 2016
- Messages
- 20,771
- Likes
- 37,635
You are correct. However, once again your defense is to indicate correlation to other reviews and your own testing results. That is the exact opposite of the circumstance I described - i.e. one in which there is no other data available. In each specified example you indicate multiple samples are involved.
I'll just give up already. Single unit sample measurements are obviously without reproach here... even in cases where Amir retests and subsequently updates his measurements or methodologies after some feedback. I believe Amir is both competent and highly intelligent... but I don't believe that necessarily translates to infallible or omniscient.
I'm starting to see some of the cult here after all I think.
Right back at ya.
There is no cult of Amir. There is no declaration that all examples tested are perfect or that there can be no defective units. To then take the leap of logic and say these tests by anyone are no better than anecdotal reports is where the problem comes in.
Have you ever worked in a testing lab? I have. You have tests and proper procedures based upon the physics involved. Your testing gear is periodically calibrated with known samples or via physical constants. As long as it is calibrated, working and you follow procedure your results are good. Even for testing of one thing. So Amir's methods are good.
Now given modern manufacturing and QC, only rarely is one sample far off from the normal were you to test 100 of them. Given that knowledge base only if results are strange or the maker knows they are far off and submit other samples do you have much reason to worry. The testing is good and reliable. The products usually are very consistent. If you don't get any red flags, these kinds of test results are far more solid than anecdotal would describe.
Anecdotal: not necessarily true or reliable, because based on personal accounts rather than facts or research.
These tests done here are based upon facts and research. And some of the facts are that modern manufactured electronic goods have very, very, very small variances. So this isn't about Amir.
Do you honestly feel you can put very little faith in the results here because only one unit is tested? Would you need 5 or 30 or 50?
