I'm trying to make a buying decision regarding my first subwoofer. One issue I need advice on is the practical, day to day value of having a remote or app to make periodic adjustments to crossover, sub volume, etc. My specific questions are:
1. I can understand the obvious value and convenience of having an app (like SVS has) or remote when you are initially setting it up, fine tuning, calibrating, etc. It's easier to sit in your seat in your typical listening spot, rather than walking back and forth to adjust the sub while dialing it in.
2. However, once you've made the initial adjustments and fine tuned the sub to your liking, how often are you likely to need or want to make adjustments in the future? Is it reasonable to assume that the main value of the app or remote is satisfied once you've dialed it in and you are not likely to need the app or remote after that? Thanks
