digital_av
- Joined
- May 30, 2022
- Messages
- 36
- Likes
- 11
I currently have two Trinnov Amplitude8 (8 channel amp) amps that have a linear power supply with <80W idle consumption each. Even so they generate more heat that I like so I'm looking for a "pure" class D /SMPS combo as replacement.
To make sure I can't go wrong I was looking at a "reference" amplifier, Mola Mola Kaluga which has 30 Watt (idle). On a 8 channel system that's 240watts which I assume would generate a lot of heat. Isn't that a bit too much if both the amplifier and the power supply are supposed to be >90% efficient ? Unless I'm missing something it looks like I would better off with the old linear power amp than a bunch of "more efficient SMPS" amps.
