iBasso DC04 Balanced Dongle with 4.4mm Pentaconn Jack
dan2021
Anyone have experience with this product? Specs look solid and the balanced output power seems enough to drive even hard to drive headphones passably for a dongle
DAC chip: CS43131*2
THD+N: -1 10dB/0.00032% (300Q load)
-108dB/0.00039% (32Q load)
Output level: 4Vrms (30022 load), 2.5Vrms (32Qload)
Output power: 195mW@32Q2
Signal to noise ratio: 133dB
Frequency response: 20Hz~40kHz +/-0.5dB
Noise floor: <0.9pV
Output impedance: <0.1202
PCM: up to 32bit/384kHz
DSD: Native DSD256, DSD128, DSD64
https://shenzhenaudio.com/products/ibasso-dc04-dual-dsd-usb-dac-4-4-balanced-headphone-amp
I use the Ibasso DC-03, with a PC and like it, I lost mine last week, but just ordered another one.
Are you going to use the DC-03 with a computer or plugging it into your phone? (or both or other).
So I'm assuming the DC-04 is decent.
I'll likely be using it for both.
With android phone for iem mobile.
With laptop pc as a mobile solution (when working at external sites) plus stop gap home solution with HD800s while I wait for my A50S to reach
I decided to just pick up one (got it used for ~30USD and couldnt resist). So far seems very solid. Powers the HD800s extremely comfortably and has decently low noise with iems.
So far, my subjective opinion:
Pros:
Super small for a full balanced 4.4mm output dongle
Cheapish (i got mine super cheap used, ~30USD)
Solid Power (I run HD800S and I rarely exceed 30% power)
Detail (not the most detailed but I also don't feel cheated of details in the music)
Treble extension (sounds pretty airy and clear - this is probably mostly the HD800 talking though)
Cons:
Soundstage width/extension (lower than normal for HD800)
Bass (quite lacking and the fact that HD800s already have lean bass doesn't help)
Lack of dynamics
I tried my newly received one over the weekend and I must say I am not impressed. I can only confirm @dan2021 's findings in every single point. Soundstage is really narrow and dynamics is lacking. I doesn't even help to put one more headphone amplifier in between, bass is lacking under such low load, too. E/g bass lines severly crumble when hard impacts hit. Test track "Under" by italian formation "Uadg", first few seconds. That track usually reveals a night-and-day difference between current stable ams and those collapsing. As a side note, the DC04 doesn't connect to USB 3.0/3.1 ports of several AMD Ryzen based machines (Windows 10 OS). Confirmend by manufacturer, to be fixed within next few weeks with a firmware update.
