solderdude
For electronics there can be a settling time (warm-up time).
This is also shown by Amir in some cases, even for digital gear (usually the X'tal oscillator)
Burn-in period for certain electronics is not weird (I do this often for fiber-optic components) but this is only to weed out the early failing components to a certain degree.
This is best done in a climate chamber at lower and higher temperatures than room temperature. Burn-in is a good term for this because of the high temperature to accelerate the time in which questionable quality components literally break. And some parts actually do. This is why some gear can fail rather soon after being used for the first time.
Although that can also be from incorrect usage or a design/test omission (L30 as an example).
Electrolytic capacitors can have a (rather short as in max a few seconds) forming effects when voltage is applied to it for the first time or when a device is switched on again after many years of not being switched on.
Tubes do age but usually not for years (unless one bought a really used 'pull' or a poor quality new one) so performance, once they are at their working temperature, can get less over time. Talking about years, not days/weeks unless the tube is faulty.
So for these reasons some people may think/believe electronics, and even cables , also need a burn-in period or should I say a break-in period for them to reach optimum quality. The 'electronics sound better' after X time (as in days or longer) is nonsensical and not supported by any evidence.
For mechanical and acoustical devices there can be some effects that can be measurable. One could question why everything is always 'improving' over time to certain folks.
Of course, people buying electronics and selling it because they don't like it after a while could be seen as proof of worsening over time as well.
Headphones... some effects can be real. Usually because of pads getting more compliant or shape better to head contours over time and create a better seal or ear-driver distance. But here too in most cases it is a matter of the brain getting used to a certain presentation. Those that regularly change headphones will undoubtedly have experienced that after a few minutes the 'weirdness' in sound after switching is gone and the headphone does not sound 'off' in the way it did when the switch occurred.
I am quite convinced that people get used to sound or become less 'in love' with their new purchase in general. For the same reason I believe 'long term listening tests' are flawed. Yet some people believe this is essential for gear to be evaluated. It has nothing to do with electronics changing but with the brain adjusting to a presentation of transducers.
