Rod
- Joined
- Mar 24, 2018
- Messages
- 761
- Likes
- 356
I use these controllers for volume control and FF/RW, moving text cursor, scrolling through streaming music list,etc. I removed the harsh encoders and replaced them with smoother ones. Then I removed the hollow 44mm knobs and replaced them with solid aluminum 48mm knobs and since the knobs were smooth metal and no texture I found some silicon rubber pipe end covers that fit great and covered the knobs with them. Then took some double sided sticky tape and stuck them together. For cheap Ali Express items they work well. I am not quite back to the pots and knobs that I remember from the 1970's and how smooth they were, but it's close. I tried to find Alps encoders for the controller instead of the ones off the Ali, but I could not find 30 position, 15 pulse Alps encoders. But the heavy solid core knobs helped with smoothing out the indents. There is a little wobble that the encoders shafts have, but for 50 cents a encoder they do well for the price.
I
