What phono amplifier for Dutch 8c
Mostec
Ljubljana, Slovenia
Hello to all, I just bought Dutch & Dutch 8C speakers. I still have many vinyl records and now I'm looking to buy phono preamp. What do you think about SPL Phonos? It has only RCA out or do I need phono with XLR out to connect it to Dutch 8C?
Thank you very much in advance.
Can you find a phono with XLR balanced outs ?
Is that required?
If you take a Parks Audio Waxwing RIAA ( Digital DSP based) you could run the SPDIF digital out to the digital input of the 8c with this.
That gives a single ADC conversion, and a perfect RIAA implementation.
I use Parks Audio Puffin with most of the Waxwing features, but no remote control.
It is a fantastic tool to tune the vinyl set up. Outputs for Waxwing is Analog RCA, digital toslink and digital SPDIF(RCA look alike) .
For other analog RIAA you could just buy a RCA to XLR cable .
I can't recommend a phono preamp.
With an RCA-to-XLR adapter cable/adapter into a balanced input you get almost all of the noise immunity benefits of a fully-balanced connection. (It doesn't always work well the other way around.)
But a balanced XLR connections on both ends would be "nicer", "easier", and look better, etc. So if you can find a preamp with balanced outputs at a reasonable price, I'd go fully-balanced.
Or, I'd get the Waxwing which doesn't have balanced-outs but it has digital record-noise reduction. I've never seen (or heard) it but record noise is the biggest weakness with vinyl and personally, it's the main thing I dislike about it!
Or, since you probably have other audio sources, you might want a "traditional preamp" (a "hi-fi control center") that might have XLR outs (and may or may-not need an external phono preamp). Or there are some AVRs with XLR preamp outputs, which again may, or may-not have a built-in phono preamp.
Review Index (upper left) > Click Audio Electronics in banner > Type Phono in search box > Read including comments on interesting candidates > Decide budget and Ask questions
Schiit Skoll, but like others said Waxwing is propably the best choice. You can connect it directly with for example optical to AES.
It is possible to use Roon and connect via the RooPlay extension using a suitable ADC. This allows use of room correction or Ubacch as well.
UBacch is now supported over AES also. So you could use a Waxwing for example with uBacch.
The most transparent solution seems to be the ADI-2/4 Pro SE. It includes a phono preamp, with part of the processing done digitally, ensuring exceptional fidelity. Moreover, only one conversion takes place: A/D from the turntable to the interface. The interface can then send the signal via AES/EBU to the 8c.
Any decently engineered phono into the 8Cs XLR’s which have been set to ‘analogue’.
