tiagobdonoso
- Joined
- Mar 19, 2021
- Messages
- 16
- Likes
- 5
Interesting! I'll try that and will post here later.Another idea: try running the amp in 220V (phase + phase) and see if it solves the issue.
I see that the OP’s amp has both RCA and XLR inputs. When I was researching Hypex amps I remember reading that this configuration was more susceptible to ground loops and it was best to have XLR inputs only and use an RCA to XLR cable. Has anyone else heard this?
Michael
BUT by turning on the video projector the ground loop came back.
@Dlomb11 audiophonics doesn’t view the buzzing as a defect because the sound to them was only audible when ear was against the tweeter (It was loud to me at six inches and was still noticeable at 2ft) and was heard on all of their nc502 inventory. Doesn’t make sense to me but they provided a refund as it was returned within the return window.
I subsequently purchased a p502 from March audio and have been using it for about two weeks. There is very slight noise coming from left speaker but I can only hear it if I put my ear right next to the tweeter - accordingly this noise doesn’t bother me. The p502 sounds great, has a much smaller footprint than the audiophonics amp, and the 12v trigger actually works with my minidsp shd. Very happy with my purchase.
I once had hum/buzz issue on my power-amp equipped HT system. I was able to localize the issue and found the root cause to be the coax cable feeding my set-up box which then pass the noise via HDMI into my receiver then into my amps. I fixed that issue by introducing a hum-eliminator coupler between the coax-cable and my Panamax power conditioner. That product is no longer available at Amazon but here is a similar product.
https://www.amazon.com/Ground-Loop-...coupler+hum+eliminator&qid=1623696883&sr=8-27
Shouldn't the Panamax power conditioner take care of issues like this?
I have 95dB speakers, should i look elsewhere then? other amplifier, Hypex, Purify.Hello,
Sorry for late reply.
Just to clarify the situation on the Hypex NC502MP module.
Yes, there is a channel with more noise than the other one. But It's really really low, not noticeable under normal use.
On 92dB speakers we can't hear it at more than 0.5 meter, with ear in axis with tweeter.
It seem to come from the module itself, as we tested it switching input cables, without input adapter board, without chassis. The bare module on a desk is having same behavior.
But I insist it should not be noticed unless you direct connect a very high sensitivity driver with at a low listening distance.
We made 2 measures at -10dbu and -100dbu input (5W and 0W output) on the LPA-S500 amplifier.
There are made with Averlab device so maybe not as accurate than Amir, but it give an idea.
Interesting, I have not a trace of audible noise/hum/buzz with my implementation of Hypex NC252MP moduleJust to clarify the situation on the Hypex NC502MP module.
I realized it was a problem with my turntable, at least I guess it was. I grounded it correctly (I was using the built in preamp) to the phono preamp and it stopped.Anything new? I'm considering Audiophonics LPA-S500NC amp for my next upgrade
