staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,855
- Likes
- 28,321
Most stand-alone recorders have a "pro" balanced XLR connection (with optional 48V phantom power) and they are not directly-compatible with "computer mics" or an electret element. Computers have a 5V "bias power" for an electret.to use with battery-powered as well as mains-powered (mic->interface->PC->mains) recorders.
Thank you for your preference list and other tips.My order of preference would be either 4 > 3 > 1 > 2 or 4 > 1 > 3 > 2. #2 has poor shield coverage, and #3 may be susceptible to RF ingress at the capsule unless you connect shield to mic case. #4 has lowest shield resistance but also somewhat higher parasitic capacitance than #1, I imagine.
I can see a few potential problems here:
1. While the capsule is quite hot, you would still want to have a quiet bias supply. How do you safeguard against devices with noisy bias (more common than you might think, onboard audio for one is notorious)? Right now you don't. I would contemplate adding a battery and some active circuitry, either in the microphone body itself or as an inline box. This could enable driving substantially longer lengths of cable as well. Somewhere I had also bookmarked an article on distortion compensation for JFETs that may be applicable to electret capsules...
2. What sort of interface will take a consumer electret? It would pretty much have to be a consumer soundcard rather than the typical USB audio interfaces for home studio use with their balanced XLR mic inputs. With extra electronics, you have a chance of accomodating both.
This being an omni capsule, I am guessing it is for some sort of measurement application? Not sure how the recorder would be used in this context though.
The recorder in my pics is a PCM-D100, which uses a 3.5mm TRS Stereo single-ended microphone input.Most mic inputs, including the recorder in your pics are balanced so none of the above. Use a standard mic cable. + to +, - to -, and shield to ground.
Thank you for your comments, fortunately I know all this already.Most stand-alone recorders have a "pro" balanced XLR connection (with optional 48V phantom power) and they are not directly-compatible with "computer mics" or an electret element. Computers have a 5V "bias power" for an electret.
"Real" condenser mics work from 48V phantom power. (Dynamic mics don't require power.)
There are some 48V phantom-powered mics made with an electret element and I assume they have an op-amp (or two) inside to get the balanced output. And, there may be a few battery-powered mics with balanced outputs. (Those were popular in the past when most mixers & PA systems didn't have phantom power but they are rare now.)
There are some "cheap" electret-based XLR mics that look like studio mics and I'd guess they don't actually have balanced outputs. Sometimes they claim they'll work with a computer or with phantom power but the specs are vague and I don't trust 'em.
Thank you very much for your insight!Method 3 is the best, and if you can extend the shield around the capsule without touch it is even better. The parasitic induced currents will flow mostly through the shield.
Method 2 is the worst, almost like connecting the capsule without shielded cable.
Method 4 will give you similar results as 1, but is a shame to not proper use the cable if it has two inner conductors.
You can get away with method 1 if you will use the microphone outdoor and the cable is relatively short, like 1..3 meters. But if the medium is heavy parasitic and/or the cable is longer, use the third method!
The shield is the most important part of an RCA interconnect cable.
While the 2 inner-conductors can carry the signal,
It's the shield that shielded the noise & interference.
Just use a coax with a braided shield for RCA interconnects.
1] All microphone cables need to have the cable shield connected at both ends.
2] Semi-pro mixers & consoles need to turn OFF Phantom power unless the microphone requires it.
For microphone cables:
If the cable shield is not attached to the microphone case, it may pick-up interference.
For RCA interconnect cables:
Always connect the shield at both ends!
The shield is the most important part of a RCA cable.
