notsodeadlizard
- Joined
- Feb 18, 2023
- Messages
- 403
- Likes
- 382
You don't have to do anything.
I have a room 2x 2metres can I treat it myself. How?
Chill guysWhat is wrong with you? Can’t you post without being rude?
I edited the post before your reply so that it is clearer.
I repeat: get a life!
Or learn a thing or two from an expert.
This! Or go to your Corners. Any more like this and thread bans will result.Chill guys
When the environment is very small, direct and reflected sound arrives very close to each other. You said you need to separate them. Why was my question?I don't understand the question, can you phrase it better?
Why? What will be the insurmountable problem?
because you want to maintain the spatial data of the recording as much as possible without it being corrupted by the room's spatial cues.When the environment is very small, direct and reflected sound arrives very close to each other. You said you need to separate them. Why was my question?
Hi, 6ms is about two meters.It will be difficult to keep early reflections and direct sound seperate. We need at least 6 milliseconds between the two, and that’s roughly 1 meter.
Like sarumbear suggests the flutter echo would be worst offender. The room i so small I'm not sure any proper acoustic treatment fits in, or if it does it gets too dead quick. But flutter echo is something one perhaps could and should address.
I understand that but what has that relate to the OP’s question? He is asking advice for that room. Is your answer use a larger room?because you want to maintain the spatial data of the recording as much as possible without it being corrupted by the room's spatial cues.
you don't want the reflections to be received as part of the direct sound. but rather (ideally) as delayed reverberation. Otherwise you're just getting a worse headphone experience with even more mediocre sound staging.
That’s not very helpful is it? Boasting about your knowledge when it’s not asked…It has nothing to do with OP's question, I was just explaining the problem with having an incredibly small room.
You literally asked what are the insurmountable problems small rooms haveThat’s not very helpful is it? Boasting about your knowledge when it’s not asked…
You literally asked what are the insurmountable problems small rooms have![]()
First I was replying to someone else second, you used the word difficult, i.e. possible but difficult to achieve, whereas it’s in fact impossible and there is nothing that can be done other than treating the environment as close-field and treat high frequency issues like flutter echo and add diffusion to reflections. I’m sure you know that too.It will be difficult to keep early reflections and direct sound seperate. We need at least 6 milliseconds between the two, and that’s roughly 1 meter.
