- Thread Starter
- #61
Weighting and non-flat noise densities can be done but it's a bit of a pain as you basically have to divide your frequency range of interest into a bunch of chunks, each with roughly constant noise density and weighting factor. (People did this for phonopre noise calculation in the '70s.) You not only have to pick the ranges but also enter the noise density as well, which quickly becomes tedious when doing it by hand. If you are happy with a flat noise density approximation, my RMS summing and unsumming calculators should do the job.
If you want A-weighting, I'd suggest using something like REW to determine the difference to flat 20-20k on your measurement spectrum (no need to reinvent the wheel if someone else has already done the work, and it keeps you from having to type a bazillion values). I have also used an A-weighting EQ preset for Audacity's filter curve effect before. (Note that A-weighting is only considered valid up to 20 kHz, and any substantial content above this may need to be disposed of using a sharp lowpass filter.) The wave file analysis of RMAA should also do the job, I think... Plus I reckon there's various metering plugins for your favorite DAW that would work.
It's actually quite easy to do.
If there is an interest, I can provide an Excel file I'm using to do that.
You export the FFT from REW.
You copy/paste the exported file values into the Excel sheet.
You set your low/high limits values.
The Excel will computes the RMS energy between your limits, with various weightings (un-weighted, A-weighted and CCIR-2k weighted) using the original weighting formulae.
The Excel includes flat energy values per default, so you may already try and get the difference of level for each weighting method for a flat noise.
