You forgot the wall behind him, which is a worse offender than the front wall.
Depends much on the constraints of the room. I was giving the key points from the actual set-up as pictured. It it is possible to flip things around, then it is another story. Also, regarding back wall, I have my own view and that is that a close back wall is not a bad as many others think or say, as long as you can adjust bass with a parametric EQ. I would say from the setup that the sidewalls is a bigger issue, one open side and one close wall/windows - not possible to adjust at all with EQ.
