JustAnAudioLover
- Joined
- Mar 25, 2021
- Messages
- 125
- Likes
- 69
Hi there!
A friend of mine recently purchased a stereo system made of two floorstanding speakers (Monitor Audio Bronze 200 6G), which are rated for 40 to 120W under 8 Ohms nominal, 4.4 minimum.
The amplifier is a Tangent Ampster BT II which is rated for 2x 25W under 8 Ohms, 2x 50W under 4 Ohms. And before you ask, it wasn't possible to choose another amplifier as it was part of a pretty amazing deal on the speaker + amp combo.
Now, the said friend has a pretty big room and likes a lot of bass, but doesn't want a subwoofer not having bigger speakers, so they just added a +10 dB boost on the amplifier's bass. This actually doesn't sound as bad as you would imagine, but I imagine it's putting even more stress on the amplifier.
They usually listen at very moderate volume but, once in a while, they like to push the volume a lot to hear the speakers from the other end of the house. This wasn't a problem with the previous system, which was a basic 2.0 LG soundbar, and shouldn't be with these speakers either, but I'm worried about the amplifier.
If the volume is pushed too high, with the amplifier being rated under the speaker's minimum power rating and the bass being boosted, may this damage the amplifier? Or worse, may it damage the speakers? I don't totally get how clipping (if that's the correct phenomenon) works, so if someone could enlighten me
I'm worried they may damage the system by pushing it too hard with high volume basically.
