How should I upgrade?
oblivion34
I use SIMGOT EM6L and I am very satisfied. It is a great pleasure to listen to music with him. I can easily understand the location of the players while playing the game. I want to upgrade to a higher model. What do you recommend I buy? I have a budget of $400. I used Truthear Zero, but the sounds were too complicated, I didn't like it at all and returned it. I hope I was able to explain my taste in sound.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I'm assuming you played around with different tips and worked to get them sealed properly in your ear.
Have you tried any other iem's, or are headphones an option?
Ze Frog
If you are very satisfied probably just best sticking with those to be honest. A lot of times the upgrade is just something new to look at and play with.
O
oblivion34
I have beyerdynamic dt 900 pro x headphones. I didn't have the opportunity to try many headphones, but I really liked the IEM world. There is no unnecessary bass in the EM6L, the sound is quite sufficient for me. I wonder if he should get Hype 4?
